Unstyled wc, help identify |
JM
Joined: 12 Sep 2009 Location: United States Points: 379 |
Topic: Unstyled wc, help identifyPosted: 28 Mar 2010 at 10:27am |
My wc is serial number wc82767, I think that is a late 38.It has no holes in the hood for the small starter tank. The engine casting number is u3019-23, It had a wd manifold and air cleaner on it. I am wondering if it is still the original engine or did somebody put a wd in it? The left side of the engine has a patch plate over it and I cant see the numbers. It also has a starter and generator, but I think that has been added as the wiring for the charging system is cobbed up and incomplete. What do you guys think? Thanks.
MNLonnie
Joined: 11 Sep 2009 Location: Baxter MN Points: 4801 |
Posted: 28 Mar 2010 at 11:05am |
The serial # would make it a 1939. Not sure on the motor.
Pipe
Posted: 28 Mar 2010 at 11:49am |
yep 39 plate on the side starter and generator should all be correct on tractor. could be a wd motor but probably is the orginal motor.
Pipe
Posted: 28 Mar 2010 at 11:51am |
tractor should be a styled tractor ?
