UC Trans Oil
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: UC Trans Oil
    Posted: 14 Nov 2023 at 7:33pm
When it’s time to change out that heavy old grease/oil that is in them, what do you recommend to use?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2023 at 10:26pm
I put 80-90 in mine. Not sure the old 140 will drain unless heated up. Had mine apart in 1974 for a bearing in trans. Think I dug a lot of the goop out by hand before gasoline bath. That was a long time ago so memory could be off.
GreenOrange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2023 at 9:16pm
I run SAE140 GL-4 in mine. Not the easiest to find and takes a lot of oil (12 gal I seem to recall).
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2023 at 7:32am
run 80-90 in mine
