Trying to Start a B (GOT IT STARTED!!!)
 Post Reply Post Reply Page  <1 234
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 5:32pm
Originally posted by AJ AJ wrote:
Thats what I thought in the beginning Bob but I musta had some real bad luck up front.
The cylinders front front to back in line go 1234 or 1243?
I know the plug wires are suppost to be 1243
The engine is 1-2-3-4 from the radiator back.
The wires go 1-2-4-3 clock ways.   You do have them wrong in your pictures. I missed that in looking at your pictures. Go back and follow the wires in my picture of the magneto to see how they go from the cap to the plugs.
Edited by Dick L - 06 Jan 2017 at 5:35pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 7:47pm
The manual that I linked says compression pressure is 94 to 115 pounds for various variations of the B/C gas or low octane fuel engine. It doesn't give any details about making the test. I'm sure that it is crucial to make sure the choke and throttle are full open. Then take the pressure as it builds, usually in my experience it stops rising after 5 or 6 compression strokes. The highest pressure reached is considered the proper reading.The starter or cranker work faster if all the plugs are out and the clutch pedal is pushed even with the transmission is in neutral.
Checking for ignition power by looking at a plug removed but grounded is not a good test of ignition. At atmospheric pressure it takes a lot less voltage to spark than it does at 100 psi or so for a normal compression. A system that sparks a plug at atmospheric pressure may not fire at the higher pressure. A more conventional test is to expose the end of the plug wire and hold it between 3/8" and 1/2" from the block or head. A good ignition system will spark that gap at atmospheric pressure. The spark has to be fat and blue. A skinny or yellow spark shows problems in the ignition system. A bad coil probably won't get voltage to jump any gap. A bad condenser will make the thin and yellow sparks and the engine won't run well with a yellow spark.
When preparing to set the timing it is important to set the point gap first because changing the point gap changes the timing.
Gerald J.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 8:51pm
I want to thank all you guys for the help, suggestions, ideas, and putting up with me. The problem was figured out. I had it timed correctly the very first time so timing wasn't the main problem. Turns out it was the plugs. Had someone call me to tell me to try a hotter spark plug. Just happened to have some laying on the shelf. Put them in, gave the carb a shot of ether, hit the starter and she fired off the second revolution. Put it on gas and hit the starter. Fired up and ran. I'm going to play with it more to get it timed exactly right and some other adjustments to see if the engine is worth a darn. Thank you guys, I appreciate the help.
Can't fix stupid
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 9:57pm
    Hey Thas great,,,,but,,,,when are Ya gonna break out the Black Label,,,,,????WinkLOL
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 10:42pm
Aj, while you have it open I believe it would be a good idea to check the valve adjustment. It seems strange to me that ALL cylinders would be so low but relative even. You could be the victim of wrong adjustment (to tight) and the overlap is bleeding off the comp. Easy enough to check. Glad you got her going!
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 5:28am
I did mention upthread that the plugs looked old. The wires probably could be replaced too. When you feel rich I'd go with new points, rotor, cap, wires and plugs. That pretty much takes care of the ignition system.
BrianC View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 5:58am
Interesting to read the thread. How confusing it quickly gets. I thought it amazing
when TDC mark was found, I zoom picture in and squinting, I think that spells "FIRE".
I read the thread late, or I would have replied on that. There was confusion about plug wire order. My first thought was which way does that rotor turn? By looking at b/c/ca tractor pictures on the net the answer is clockwise.  Magneto or distributor, they both rotate clockwise.
You can now see the Fire and Center marks, get some paint and fill in the engraving for the line and letters, for yourself and for future generations.
I didn't see anyone ask you to test for side play in the distributor shaft and bushing.
If this is worn the engine will run poorly, due to "random" spark.
If it were mine I would verify valve lash, check point gap on all 4 lobes. Start it up run it at top speed, use a timing light with that FIRE mark, set the timing. Start reducing rpm with throttle at 900 rpm and below, the fire mark should start moving down out of the inspection hole as the distributor advance alters timing closer to TDC.
And if you don't have a nice blue spark, file points ,replace points, replace capacitor.
You replaced plugs and now it works, so I have my doubts about the quality of the spark. Another sideshow is do you have the right coil? Things get botched up with 6 to 12v conversions, coils and resistors...
Glad it is running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 10:33am
AJ,
You did very good with a lot of good instructions! I have had similar issues with tractors. and Its just a lot of checking! for spark, compression and gas. If they have those things they should run, Maybe not very well but they should fire and try to run.
So taking number 1 plug out and grounding to the block and looking for spark might have given you a lead on the problem sooner. That's what hind site is good for!
 Glad you got the B running. I bet the compression is better now too?
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2017 at 9:13am
Craziest thing- I've been resurrecting a B that had a stuck piston (among other things) and finally got it to the point I was ready to try and start it.  I timed the magneto...timed it again...tweaked it a little, etc.  Then I changed 3 of the spark plugs back to the Champion J8s that were in it when I got the tractor, the 4th was rusted badly from the cylinder that was stuck, and after the plug change, she started up and ran like a champ for the first time in years.
So...why would it start on 3 J8s (and one AL 295), but only sputter a few times with 4 AL 295s?  Voodoo?  Luck?
1951 B
DaveKamp View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2017 at 12:14pm
The question isn't why it would start on some and not others, it's what would prevent it from starting. Spark plugs are doing a seemingly simple job, but it's not that simple of a situation.
The concept is to provide a spot for a spark to form, and create enough heat to ignite fuel. In order to have a spark, you have to have an open circuit... meaning, the insulation between center electrode and outer exists. If the insulator has carbon built up on it, electricity will leak across the carbon, preventing a spark from forming.
There is a reason why spark plugs come in different 'heat' ranges. It's obvious to most why you'd not want to 'hot' a plug... 'autoignition temperature' is the temperature AND PRESSURE at which point a volatile mixture will just ignite. IF a plug's electrode was so hot that it was glowing red, you wouldn't need a spark to cause the fuel/air mix to touch off... as soon as the compression pressure is high enough for the fuel... and that hot spot... to light up, you'd have fire... This is exactly how 'hot bulb' diesel engines work... but in a gasoline engine, we call it 'pre-ignition'.
(it's bad in gasoline and gaseous-fuel engines because the flame speed and expansion/pressure rate is really high compared to 'heavy oil' engines)
So what about a 'cold' plug? Well, fuel burns... it's called a 'chemical reaction'... and in any chemical reaction, you start with one thing, get some energy out or in (exothermic or endothermic), and when that's done, there's always stuff left over.
If it was a pure fuel, and the mixture was ABSOLUTELY PERFECT, you'd have a very predictable basket of leftovers. In the case of a hydrocarbon fuel, the results of a 'perfect' burn are MOSTLY carbon dioxide and water... but usually some carbon monoxide, and some other nasties, and leftovers of whatever dust, dirt, crud, corrosion, etc., found it's way in through the intake, fuel system, whatever. Aluminum oxide from the inside of the carb bowl, bits of bug guts, some oil through the rings and valve guides, a little iron dust... 'yknow... crud.
And to make for clarity... NO engine I've ever seen, manages a 'perfect' burn. If you feed it ordinary pump gas, you ain't gonna get one... because it's a mixture of hydrocarbons... and frequently a carbohydrate (ethanol), and of course, crap and water.
So what happens, is the leftovers of the burn accumulate in places where they 'like' to stick. Typical barnyard carbon likes to stick to hot surfaces... it kinda likes to 'coat' them, and the spark plug electrode is one of those places. Carbon ain't much of an insulator... matter of fact, it's really handy for making resistors (electronic parts). It actually conducts electricity, but not very well... but enough so that it'll 'bleed off' your spark energy before the VOLTAGE across the plug electrodes reaches high enough to 'excite' the atoms between the gap... and the result, is no sparky arkey.
Remember that there's 'water' as a leftover? Well, wet carbon turns into a dead-short really fast. Lots'a guys will check for spark by lifting a wire off the terminal of a plug, and see a nice blue flash... but that doesn't mean you're getting a flash across the electrode inside. You can also pull the plug and watch it spark on the outside, but once it's threaded into that dark hole, and there's watery oily used-to-be-gasoline in there, it'll be just another dead-short.
So putting three new plugs in, made those three fire. What about the fourth? Well, once the engine's turning fast and warmed up, the mere presence of airflow through, and a rise in temp, will eventually clean up that one plug enough so it'll start to pop, then run.
Cleaning up the old plugs may very well result in them working fine, now that the engine's been fired up, warmed up, and happy. Matter of fact, now that it's been warmed up and cooled down a few times, a socket on that last plug, and light tap from a hammer on the side of the socket may break those threads loose and back it out nicely.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2017 at 12:22pm
Finally... it's important to remember that when you're foiled by an engine that won't run... even after you've checked EVERYTHING...
It's not that you've overlooked something...
It's that you ASSUMED that something you HAVEN'T overlooked... is actually as you thought.
These machines' spirit exists within YOU. You work on them, and you learn their story... and they vex and challenge you. They torment you, and when you finally get them alive, they warm you, they sing you their song.
But remember- they are just machines. If you think they hate you... if you think they're evil demons that poke you with electrified, hot spears in jest of all your blood, sweat and tears, they're just machines.
This is why it's best, when put to the test, to put the tools down and grab the phone, call a friend over to visit your home. Tell them nothing of what you've tried, just hand them a beverage and tell 'em you're fried. Stand back and watch, but keep your mouth shut, give them a chance to drag you out of your rut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2017 at 12:40pm
Thanks for the input- a lot of good advice and wisdom in what you say.
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2017 at 7:17pm
Maybe you got the wires right after changing to the Champions Shocked
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2017 at 7:49pm
PURE POETRY!  Thank you!
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
brkfldj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brkfldj Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2017 at 8:45am
I enjoyed, continued my education, and empathized as I read this old thread. I am guilty of the erroneous assumption too many times.
DaveKamp, you have been quiet for some time. I look forward to your analysis and perceptions.
Thanks to all that share their knowledge.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2017 at 10:32am
Yeah, I'm guilty-as-charged... between work, taking Nick to work (For some strange reason, school permit doesn't allow a responsible kid to drive to his job and back...) and taking Libby to soccer games... and working towards getting foundation laid for the new workshop, and bicycling and motorcycling... boating and more work...
I've been kinda missing from this, and other forums (Smokstak, Practical Machinist, WeldingWeb)...
How's the line go... "I'm Sorry Spanky, I guess I just hafta live my own life..."
One of these days, I'll get back to Schwartz... get the steering cylinders and column done, get the loader fitted, engine running, controls operational...
This page was generated in 0.088 seconds.
