Trying to Start a B (GOT IT STARTED!!!) |
Page 123 4> |
AJ ![]() Orange Level ![]() Joined: 31 Oct 2010 Location: mo Points: 5244 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Jan 2017 at 9:57pm |
Have a B engine I have been trying to get to start for the last three days. Just thought I'd throw it out on the table incase I'm missing something.
Borrowed a carb from a running tractor. Engine is getting spark. And is timed correctly I'm pretty sure. I know this because when I went to double check the timing i hit the starter to bring it to #1 cylinder and the plug wire was touching the top of my hand and hit me at the same time when the distributor hit for spark for #1. Yes it getting fuel too. Engine will hit once in a while on one cylinder but that it. Thoughts? Questions? Ideas? Edited by AJ - 06 Jan 2017 at 8:52pm |
Can't fix stupid
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5050 |
Are you sure your timing isn't 180 degrees off?
Pretty sure. I've tried the 180 rotation trick already. Not saying I'm correct but it has me scratching my head.
Can't fix stupid
JD Dan ![]() Orange Level Access ![]() Joined: 12 Oct 2014 Location: Cattaraugus, NY Points: 506 |
Didn't the b have 2 different possible firing orders? Also, have you noted if the spark is consistent or erratic? In the last year I've had at least a half dozen customers that tried to save a few bucks on ignition parts only to wind up calling me to fix it. In every one of these cases the condenser was faulty causing erratic spark which appeared to be a good hot spark properly timed
Well Dan, I'm open to any possibility at this point. How do I check that properly?
Can't fix stupid
Larry in NC ![]() Orange Level ![]() Joined: 09 Feb 2016 Location: NC Points: 1050 |
You have spark, but if you have not done so, pull the plugs and make sure you have hot spark all the way through the plugs. If the plugs are wet they are not firing. Fouled plugs can cause the problem you are having. Firing order is 1-2-4-3. clockwise. If the tractor has been sitting a long time, look at the ends of the spark plug wires in the distributor cap to see if they are corroded. If the tractor has a distributor, it could be set wrong even though timed correctly. You can try moving it clockwise to increase the timing.
Bull ![]() Orange Level Access ![]() Joined: 28 Sep 2010 Location: Lamar, Missouri Points: 589 |
Is your TDC timing mark showing when # 1 piston is up? While working on my C I mistakenly had it on the fire mark instead of TDC mark so it was off 30 degrees.
WD45 Diesel, RC,CA,IB, B, G, 616, Early B-10, D-10, Terra Tiger, 95G spreader, SC blade
I have not check that yet Sam and I will. BUT I just realized something that I should probably look at again. I replaced the governor in it because the old one was shot and not sure if I paid attention to the timeing mark on it. That could possibly be an issue worth pursuing.
Can't fix stupid
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5092 |
This is the way the wires should be for the proper firing order. Make sure you are on the compression stroke for number one plug at top dead center when the magneto snaps. Make sure that TDC or CENTER line is in the inspection hole. If not seen adjust until it is. With all the plugs removed turn the engine over to where it snaps and you see spark for number by holding the wire close to the block. When you see this then check the number two plug wire the same way. You then check the number four wire by seeing the spark. then last check number three wire. When turning by hand watching spark on one wire and stopping then going to the next wire for the check you leave nothing to chance. You are able to see spark and know it is in time as long as you have number one correct. ![]() Edited by Dick L - 04 Jan 2017 at 11:58am |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88405 |
follow Dicks procedure. I would bet the timing is off. pull the wires off and put a plug in #1 wire and ground it... turn the crank slowly with somebodys thumb over the plug hole to feel that your coming up on compression stroke... continue to turn until it fires on #1 and you see the spark. Look in the timing hole and should be TDC showing.. helps to have a second person looking in the hole to assist.... Im guessing your off on this.
Edited by steve(ill) - 04 Jan 2017 at 12:05pm |
Update. Went home on my lunch break because this is driving me nuts and want to get this figured out. The governor was out of time. Took governor out and turned the crank till the mark was visible. Put governor back in lining it up with the mark. Fixed that.
Re-timed the engine to number one cylinder (blow the finger out trick) Think it was 180 out at that point. Adjusted the wires to firing order 1243. Engine still not doing anything Edited by AJ - 04 Jan 2017 at 12:18pm |
Can't fix stupid
Not sure if this matters but I'm running a distributor Dick |
Can't fix stupid
I thought I had done that. I must still have something off.
Can't fix stupid
Do you have a distributor or magneto???
Distributer
Can't fix stupid
Here ya go. You find the TDC on the compression stroke again for number one. Remove the distributor cap. Loosen the base of the distributor. Make sure the rotor is pointing to number one terminal. You may or may not need to lift the distributor up and turn it so when setting all the way down it is pointing to number one terminal. With the points set at .020 when setting on the high point of its shaft cam. rotate the distributor base back and fourth with the switch on watching the points spark. Stop and lock the distributor down when the points are just about to spark. (just before) This will have it in time as close you will get it without a timing light. With a distributor you do not need to set the governor gear at the timing gear mark. That is for the magneto to make the magneto drive slot horizontal for proper magneto timing. The gear can be anywhere as long as the rotor is pointing to the number one terminal as a starting point. As stated above you lift the distributor out and turn it to where it needs to be. When I would put the distributor in my stock car after having the engine out I timed it in the dark with a flashlight more times than not. Which happened way to often trying to run two nights a week. Edited by Dick L - 04 Jan 2017 at 3:29pm |
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3073 |
WF owner - That's a great timing explanation. I have a thread on rebuilding my WD45. When I get to the timing portion, I'd like to make a link to your page or copy and paste to my rebuild thread. Good straightforward explanation. |
Top Dead Center
![]() Distrubuter pulled out and turned to #1 ![]() Cap replaced on distrubuter, wires double checked ![]() |
Can't fix stupid
Still not hitting
Can't fix stupid
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
How old are those plugs and wires? The plugs look like they still have the original orange paint on them.
"distributor pulled out and turned to #1"............ and rotated and locked in position so that the point is just starting to open ??
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5903 |
Don't believe 'Gasoline' has been mentioned in any of the Posts. Have you got gas flowing in to the carb. ? Put some gas in a windex bottle. Spray a bit into intake side of carb, then try starting. You need fresh gas. Gary |
Plugs and wired are getting great spark at the plugs. Ive checked three times. Carb is off a running tractor. Just ran that tractor 10 min ago. Plugs have been getting hints of gas on them.
Edited by AJ - 04 Jan 2017 at 5:17pm |
Can't fix stupid
Its gotta be a timing issue. I might have it all jacked up now.... I've never had this big of an issue before.
Edited by AJ - 04 Jan 2017 at 5:18pm |
Can't fix stupid
Did you remove the rotor and rotate the distributor with the switch on watching it spark?
Yes, getting lots of spark at the points
Can't fix stupid
All an engine needs to run is compression with a fuel mixture in the firing chamber with properly timed spark. If you are at top dead center with both valves closed on number one cylinder and have the spark at that time you are in time.
The only problem I could see in your case would be would be lack of fuel or both intake and exhaust valves not being closed. If both valves are not closed you are not on the compression stroke. Because of my crippled left hand I can not check with my thumb and the valve position is how I check for compression stroke. If you had the crankshaft out the other thing I could see would be the camshaft and crankshaft were not in time. Checking for the valves being closed would mean that could not be the problem. |
Page 123 4> |
