trying to source bearings for local farmer,
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2016 at 9:28pm
Rays out in Kansas would have those bearing. May have the bearing holder to ?? 785-353-2392
Ajstev1@gmail.com View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ajstev1@gmail.com Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 7:31pm
Hi I'm looking to take your advice and replace with two bearings do you have a part number or place I can purchase these bearings by any chance. Thanks for your help.
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 9:36pm
I have the hex 1inch bearing. 785-353-2392 Rays
RDearing View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RDearing Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2018 at 4:39pm
Ray do you still have these 1" hex bearings?
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2018 at 5:07pm
That looks similar to what Kewanee used, I used to get them from these guys: http://beaverbearing.com
Tb78 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tb78 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2025 at 6:50pm
Ray i am looking for these 1 inch hex bearings also
Tb78 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tb78 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2025 at 6:52pm
Did you ever find these bearings i am also looking
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2025 at 8:15am
Tb78.  Check out a knowledgebase artil I wrote maybe 15 years ago now (WOW)
The bearings are no longer made. I made an article about how I rebuilt mine. It's not really a bearing. It a bearing asselbly. There is a standard bearing in the middle surrounded by bushings and seals.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2025 at 10:03am
I used 2 of 88107A bearings pressed the old out pressed in the new bearing I did 8
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2025 at 10:51am
I'd really wonder about having something machined to the right size to accept 2 regular bearings. Likely wouldn't cost anymore, especially considering you need 6, and somebody put $300 a piece when last available. Would also be servicable down the road. That site you pasted is A&I. Available at basically any dealer. A-206KRR6-P would fit with a new housing, and a small spacer between, (which you'd definitely need for when you tighten things down). Machine the housing with an inner shoulder, slide the first bearing in, then the spacer, then the second. Hold with a snapring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2025 at 8:36am
Note the ID of the bearings are not the shaft size whether using a round of hex gang axle. The bal-pak bearing Had a sleeve pressed into the ID of the bearing and bushings. The ID of that sleeve is the right size for the gang axle. You don't just slide all those pieces onto the gangle axle.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2025 at 9:00am
Look on McMaster Carr, I found a hex core example.
Dig around there for correct size.
This page was generated in 0.176 seconds.
