Truck tires on my 616??
bamaboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bamaboy Quote  Post ReplyReply Direct Link To This Post Topic: Truck tires on my 616??
    Posted: 21 Dec 2016 at 7:25pm
Has anyone ever mounted light truck tires on a power-max? I was wondering if a set of 31/10.5-15s mud grips would fit, or even 33s"?? If I cant go that route, I guess since chains seem to be elusive, I'm going to try and make my own.
I'm almost done making weights, they are getting close to weighing 50+ pounds each!
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 8:29pm
i had 31 x10 .50 with calcium on my 616 when i got it they were pickup tires  they worked ok , but replaced them with four  (duals) 9.50x 16 firestone field and roads  .  then replace the fronts with 5x12 firestone tri ribs,  i am happy with that .          how thick are your wieghts ?   i started cutting out 1 inch plate 12 inch dia. for weights last winter when we slowed a little havent done the math or weighted any was going to put four on a side
Post Options Post Options   Thanks (0) Thanks(0)   Quote bamaboy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 10:28pm
I'm using metal I can find in pairs, I have 2 10x1" thick pipe caps, 2 8x1" pipe caps, 4 rollers from a machine, and 4 plate counter weights. Gonna be pretty thick and stick out some, but it's what I found for free to work with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bamaboy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 4:24am
Please tell me more about "dual tires" did you buy, or make adapters? What wheels did you use? Got any pictures?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2016 at 11:07am
will try to post pictures this week have to re learn
This page was generated in 0.438 seconds.
