Truck tires on my 616?? |
bamaboy
Topic: Truck tires on my 616??Posted: 21 Dec 2016 at 7:25pm |
Has anyone ever mounted light truck tires on a power-max? I was wondering if a set of 31/10.5-15s mud grips would fit, or even 33s"?? If I cant go that route, I guess since chains seem to be elusive, I'm going to try and make my own.
I'm almost done making weights, they are getting close to weighing 50+ pounds each! |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 21 Dec 2016 at 8:29pm |
i had 31 x10 .50 with calcium on my 616 when i got it they were pickup tires they worked ok , but replaced them with four (duals) 9.50x 16 firestone field and roads . then replace the fronts with 5x12 firestone tri ribs, i am happy with that . how thick are your wieghts ? i started cutting out 1 inch plate 12 inch dia. for weights last winter when we slowed a little havent done the math or weighted any was going to put four on a side
bamaboy
Posted: 21 Dec 2016 at 10:28pm |
I'm using metal I can find in pairs, I have 2 10x1" thick pipe caps, 2 8x1" pipe caps, 4 rollers from a machine, and 4 plate counter weights. Gonna be pretty thick and stick out some, but it's what I found for free to work with.
bamaboy
Posted: 22 Dec 2016 at 4:24am |
Please tell me more about "dual tires" did you buy, or make adapters? What wheels did you use? Got any pictures? |
HudCo
Posted: 25 Dec 2016 at 11:07am |
will try to post pictures this week have to re learn
