transmission drain plug location on D14
jtheise4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtheise4 Quote  Post ReplyReply Direct Link To This Post Topic: transmission drain plug location on D14
    Posted: 10 May 2011 at 9:56am
I have a 1958 D14 (SN 13572) and I can't locate the transmission drain plug (the manual doesn't show it and there's 50 years worth of dirt and grime making finding the plug difficult).  Can someone either point me in the right area so I can poke around and locate the plug or better yet, post a picture?  Thanks so much.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 8:40pm
Parts book shows it to be just in front of the rear axle housing, in the center of the Transmission/differential housing. Bob
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 9:24pm
Scrape off the dirt and grime, there is a big flat nut under there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtheise4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2011 at 7:03am
Thanks!  I knew it had to be there!!!  Don't know how I can't find a 1 1/8" bolt head, but I guess that's what 50 years of dirt and grime will do.
