Trailer Plow
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Topic: Trailer Plow
    Posted: 27 Apr 2023 at 12:39pm
I was plowing with a neighbor’s pull type plow and notice the tail wheel is being drug sidewise in the furrow. Why is this happening? It behaves normally when the plow is out of the ground.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2023 at 1:27pm
Is that how it's made? No load on it just dragging along? Maybe it's the design. Maybe to get it out of the way when tripped that's all they could come up with?
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2023 at 4:22pm
Is the mount that holds it bent or slightly bent?  I struggled with a brush hog for over a year trying to figure out why the tail wheel drug sideways vs. rolled when it was lowered.  Turns out the mounting was bent and caused the wheel to go sideways when lowered.
D17 Series 1
Allis B- 1939
Allis B- 1945
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2023 at 4:56pm
What brand of plow?  Some had a lock on the wheel to keep it straight, sometimes this would get loose and turn, sometimes if the plow was tripped into the ground while turning the guide would miss and the wheel would run crooked.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2023 at 5:03pm
I know the john deer 3-14 trailer plow I have has a pin at the top of the tail wheel linkage, that keeps the TW straight for road transport.  Pull the pin, and it follows the furrow.  Might also be how the drawbar is set, and how the plow is adjusted...
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2023 at 8:42am
It is a JD so it may simply be laying down on the job! The plow is not adjusted to take a full cut with the furrow wheel riding partially up out of the furrow. I’ll check to see how it works with his Case. I’m thinking something is out of wack with the trailer wheel.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2023 at 12:55pm
Define sideways….some models the tail wheel is set with “some” lead, to steer into the unplowed ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2023 at 9:21am
Laying sidewise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2023 at 9:23am
In the furrow. No thread running in the same direction of the furrow. The wheel is being drug sidewise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2023 at 11:44am
Ok, just checking. That sounds bad
This page was generated in 2.703 seconds.
