Trailer ball lube ?
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Trailer ball lube ?
    Posted: 16 Sep 2022 at 1:08pm
Haul my old D 15 100 miles 2 or 3 times a year . Never put anything on the ball . Just wondering what you fellas do ? Thanks !
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2022 at 1:11pm
I do for sure,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2022 at 1:21pm
Have not ever, been towing for close to fifty years, No Lube on the Ground Circuit even as has a wired one.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2022 at 1:28pm
well, I don't ground via the hitch, but I still do not grease ball, as I noted long ago that despite all efforts, that grease on the ball collects dirt and becomes a grinding compound.
I am still confident of this;
Wait for the Lord;
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2022 at 1:37pm
Just laughing at this discussion!  Have heard the same exact debate with the same exact sides here at work more than once!LOL
The ground circuit comment: reminds me of another pet topic of mine, and this time related, dielectric grease.  Had a guy one time say, exact words: "I use dielectric grease on the hitch ball SO THAT I get a good ground!"  Mmmkay!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2022 at 1:42pm
Have had ground wire connections fail, do not lose the lights but realize it as the trailer will ground thru the hitch and lights flicker on bumps.  Simplest diagnosis out there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2022 at 1:52pm
Totally understand that.
Don't think dielectric grease would help you though!WinkLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2022 at 1:54pm
Nope, a Disconnected Ground as the ball to hitch parts is still disconnected.  That and the Grinding compound comment, Absolutely on retaining dirt, sand, all manner of grit.
Edited by DMiller - 16 Sep 2022 at 1:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2022 at 1:57pm
Like I said, totally understand.
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2022 at 2:31pm
WOW!! Maybe I should have explained myself a little better, I wouldn't put grease on a bumper pull for the simple fact if anyone can get a pants leg greasy it's me. I don't have any bumper pulls anymore everything I have including the camper have gooseneck hitches. I just get up there,wipe the ball off,give it a shot of dry lube and go on, been doing that for 50 some years, never have had an electrical issue, bottom line is I have this absolute fear of bare metal on bare metal.
Dale (Stonelick) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2022 at 3:04pm
I've had a couple major negative experiences where the hitch coupler detached from the ball when I drove over uneven ground.  I thought everything was solidly connected (especially the second time), but it wasn't.  Mentioned this to my BIL and he said his father told him once to never forget to grease your ball.
I think my problem was that the hitch and ball had so much rust that the coupler underjaw was not fully sliding and engaging under the ball.  Since I started greasing my trailer ball (I just use petroleum jelly) I haven't had the problem.  I also pull up hard on the trailer tongue to make sure it is solidly connected before proceeding. A little messy, but well worth it to me.
1951 CA - 1944 C - 1949 B - Kubota M6800
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2022 at 4:56pm
I use a slip on cover on the hitch ball.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2022 at 7:29pm
Sorry, wasn't trying to cause trouble. I always pull my ball mount out of the receiver and put it under the seat , so don't want a greasy mess. Maybe a dry lube and a clean up before removal is the answer ? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2022 at 7:39pm
for twice a year hauling......... i would not worry about it.ddddddd
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2022 at 7:59pm
I carry a one pound tub of grease in the trucks and smear the 5th wheel plate or gooseneck ball each time the trailers are separated. Split tennis balls do a good job of covering the greasy hitch balls but just a blob on the ball to and a quick swipe around the perimeter is all that's needed. Remember from all those years ago the "Brylcreem" ads:
"A little dab'll do ya".
This page was generated in 0.290 seconds.
