Tractor and plow ? |
   R Aiken
   Joined: 11 Sep 2009 Location: wc Ohio Points: 1370  |
      Quote   Reply
     Topic: Tractor and plow ?Posted: 12 Apr 2010 at 7:42pm  |
   Will my D19
  ![]() with this AC 3pt hitch
   R Aiken
      Quote   Reply
     Posted: 12 Apr 2010 at 7:45pm |
   And this plow work togather.
   Roger Nolin
   Joined: 12 Sep 2009 Location: Monroe Iowa Points: 189  |
      Quote   Reply
     Posted: 12 Apr 2010 at 8:00pm |
I think it would, can't see why not.< id="gwProxy" ="">< ="jsCall;" id="jsProxy" ="">
   JoeO(CMO)
   Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696  |
      Quote   Reply
     Posted: 12 Apr 2010 at 8:09pm |
   It should take it with ease.  You will need to take all sway out of the 3 point adaptor to keep it in control making full use of the steering of the plow.
  When a semi-mount is used for instance on my 185 it has to have the sway blocks on-no side movement.
   Butch(OH)
   Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842  |
      Quote   Reply
     Posted: 12 Apr 2010 at 8:23pm |
   Yes it will hitch together, no it will not work as it should. A 3 point mounted or semi mounted plow needs one of two things to maintain any kind of even depth. A combination of draft and position control, or a gauge wheel, you have neither.  If your hold works well on the lift arms you might be able to use it and the traction booster to maintain some semblance of even depth but I wouldnt want the job of trying to keep up with the levers for too many acres.
   EdIL
   Joined: 12 Sep 2009 Location: Metamora, IL Points: 69  |
      Quote   Reply
     Posted: 12 Apr 2010 at 8:26pm |
   That 3 pt adapter is a little on the light side to handle the lateral force and weight of the 4 bottom plow.  The adapter typically breaks near the front weld on the left hand side.  I've seen many broken with a lighter load applied.  Also, the vertical adjusting link on the left hand arm on your adapter is usually on the right hand side to level the implement when the tractor is in the furrow.  Good luck!
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
