Traction Booster Gauge
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Topic: Traction Booster Gauge
    Posted: 23 Apr 2012 at 8:43pm
Just curious when the A-C tractor is started where is the needle of the tractor booster gauge suppose to be?  All the way to the left, in the middle or all the way to the right?  And should the lever on the steering column be all the way down or all the way up?
Sorry for the silly questions, but I just never used the traction booster system and would like to learn about it.  Thanks in advance for any assistance!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 9:56pm
Lever is ALWAYS down unless holding (middle) or raising.Never had a guage but sure it should read nothing when not lifting. This is for WD/WD45.D-series you set the notched lever for T/B position and leave it then lift and lower w/lever behind it
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 10:03pm
the WD / WD45 only has 1 lever. Up to raise, down to lower, traction booster in between. You move the lever up and down slightly until you find the correct spot. The TB gauge should read 0 unless it is reacting to a tough pull situtation, then it could go all the way up and then back down. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 10:48pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2012 at 5:31am
The 'Traction Booster Gauge' is a 'Pressure Gauge' and it is monitoring the pressure in the hydraulic lines going to the 'Rear Lift Arms'.
Gary
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2012 at 5:47am
When working should fluctuate in the center area. When lifting to the right.
As said above, it is a hid.. Pressure guage.
Good Luck!
Bill Long
Edited by Bill Long - 24 Apr 2012 at 5:48am
This page was generated in 0.035 seconds.
