Print Page | Close Window
Traction Booster Gauge
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=49495
Printed Date: 24 Aug 2025 at 6:37am
Topic: Traction Booster Gauge
Posted By: EPALLIS
Subject: Traction Booster Gauge
Date Posted: 23 Apr 2012 at 8:43pm
Just curious when the A-C tractor is started where is the needle of the tractor booster gauge suppose to be?  All the way to the left, in the middle or all the way to the right?  And should the lever on the steering column be all the way down or all the way up?
Sorry for the silly questions, but I just never used the traction booster system and would like to learn about it.  Thanks in advance for any assistance!
Posted By: SteveM C/IL
Date Posted: 23 Apr 2012 at 9:56pm
Lever is ALWAYS down unless holding (middle) or raising.Never had a guage but sure it should read nothing when not lifting. This is for WD/WD45.D-series you set the notched lever for T/B position and leave it then lift and lower w/lever behind it
Posted By: Chalmersbob
Date Posted: 23 Apr 2012 at 10:03pm
the WD / WD45 only has 1 lever. Up to raise, down to lower, traction booster in between. You move the lever up and down slightly until you find the correct spot. The TB gauge should read 0 unless it is reacting to a tough pull situtation, then it could go all the way up and then back down. Bob
Posted By: CTuckerNWIL
Date Posted: 23 Apr 2012 at 10:48pm
Posted By: Gary
Date Posted: 24 Apr 2012 at 5:31am
The 'Traction Booster Gauge' is a 'Pressure Gauge' and it is monitoring the pressure in the hydraulic lines going to the 'Rear Lift Arms'.
Gary
Posted By: Bill Long
Date Posted: 24 Apr 2012 at 5:47am
When working should fluctuate in the center area. When lifting to the right.
As said above, it is a hid.. Pressure guage.
Good Luck!
Bill Long
