Track Roller Lub
Ullrich Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ullrich Farms Quote  Post ReplyReply Direct Link To This Post Topic: Track Roller Lub
    Posted: 07 Aug 2019 at 8:36am
Servicing an HD6B and need to know what is a good track roller lubricant?
Thanks for any recommendations.
Ullrich Farms
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2019 at 10:19am
the rollers use a gear lube oil which is added using a tube incerted into rollers and allowed to fill cavity until oil flows back out around the tube . I have heard of people using a 000 grease also and adding it by same method .
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2019 at 10:31am
Anything is better than nothing. I have a Cat with "sealed for life" rollers, notice a little oil leak and before I knew it,it was junk. So the next one that leaked, I filled right away with a 00 grease it has gone 100's of hours. I have been told the Cat sealed rollers are filled with 30 wt,real thin anyway.
I assume your HD6 still has what they called 1000 hour roller rather than sealed for life. In the day the right grease was rather thin about the same as is called "corn head grease" today.
