track pins
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: track pins
    Posted: 03 Mar 2012 at 4:39pm
I am not having very good luck to date, Minnpar says the supplier is discontinuing pins and bushings for the old Allis/FA track, no demand, I am in bad need of two decent order master pins/link sections to repair the rails on my new acquire and seems no one has any as they did have bushings and spacers.  7G, 7GB and HD11 all used 7.0 pitch with 1.554 pins, there has to be a few still around.  I can find no specs as to rockwell or alloy so I can get a reasonable close blank stock to make my own.  Rail eyes are pretty beaten up but I think I can get a repair on them.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 5:29pm
Try some of the smaller track shops .
Thill track and tractor in Eau Clare WI
Crawler Welding in Mankato MN
Northern Tractor in Osseo MN
Northern Engine and Supply in Duluth MN/ also Montana.
Should be some in your area also
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 6:20pm
I may have a couple of links, bushings and pins laying around to fit 7G and the old HD11- I'll check if you are interested.  We cut a track down from 41 to 38 link a few years ago...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 2:18am
Hi Coke, did try Thill and a assortment of others all across IL and Mo, sent mail to at least seven so far with poor to no responses all the way out to PA and OH.  Looks bleak.  I have sent lazyts a PM, may do me some good if he can let them go.  This forum has been a wonder as to finding some of the odder stuff I have had need of.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 10:14am
Track Press Services
Our Proctor, MN location handles all of our Track Press Services.
Please give us a call for more information. (218) 628-2337
http://www.northernengine.com/Parts.htm
Edited by Coke-in-MN - 04 Mar 2012 at 10:15am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 1:49pm
Sent them a mail, will see what happens.  Thanks Coke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 6:45pm
Here's what I found:
-Several side bars, marked Berco AC404, measuring 3.85 inches tall
-One new Berco AC1972 master pin group
-Two new master pin groups- unknown manufacture
-One new master bushing
-Several used full length bushings  (could be cut down to make another master)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 8:13am
If you can part with the pin sets and bushings(all) I will buy, send me a PM with a price and address, will go from there.  It will be in US funds.
This page was generated in 0.111 seconds.
