Torque specs for WD
Phil (WY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil (WY) Quote  Post ReplyReply Direct Link To This Post Topic: Torque specs for WD
    Posted: 08 Jul 2010 at 4:18pm
Can anyone tell me the torque specs for the rod bearings and head bolts on a
WD?  I finally got all my parts I need to put it back together.  Thanks i advance.  Phil
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2010 at 4:43pm
Could not find my WD book,  A D17, rod bolts 45 to 55,  head bolts 1/2" 90 to 95, 7/16" 70 to 75.  A WD would be close.
Fidel513mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fidel513mo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2010 at 5:34pm
phil you need to be sure you placed your rod to piston and pin correct. if not you will scar the sleeve wall.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil (WY) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 4:22pm
Thanks for the advice.  What do I need to be sure of when putting together rod, piston and pin?  Phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fidel513mo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 6:35pm
you will need a it manual it shows what the placement is. if i knew how to post and scan it out of my manual i would. maybe one of this site members could. sorry.
