Corn harvesting: Picker or Combine?
MoPete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoPete Quote  Post ReplyReply Direct Link To This Post Topic: Corn harvesting: Picker or Combine?
    Posted: 29 Dec 2014 at 12:16am
I will be raising hogs so the corn will be for feed, not for sale. I have both bins and cribs available for storage. I have an auger but not an elevator. I will be saving back seed to plant so having some dried on the ear might be good and I can grind the ears cob and all. I have a small grain head on a JD45 but no corn head and I am told they are a bear to change out.
So...should I be looking for a combine or a corn picker to harvest maybe a maximum of 100 acres of corn? I want to keep my equipment maintenance costs to a minimum so I am leaning toward a two row picker. I can likely pay the same price for that as for a 105 model (JD) combine I have been looking at.
Suggestions?
Edited by MoPete - 30 Dec 2014 at 5:49am
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 4:15am
You could harvest corn with the grain head. Try to cut just below the ears but you will run a lot more of the corn stalks and leaves through the combine and probably flush more corn out the back.
It might be more profitable to hire the harvest with modern equipment done in a day or two than to keep up with the repairs of rotting parts in an antique combine with limited parts availability. I don't think Deere keeps those parts on hand anymore, I know 3300 and 4400 parts are disappearing from the Shoup catalog as the more modern machines do a better job. 100 family combine parts are getting rare, but when used they wear and break too.
Or fence the field and let the pigs do the harvest over the winter. They will eat stalks, leaves, and corn.
Gerald J.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 4:45am
I wouldnt save the corn for seed to plant. It wont do any good. Hire it done and put it in the bin if you have a way to put air on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoPete Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 5:24am
My concern with hiring it done is the actual getting it done as folks are having a hard enough time getting their own harvest in. Also, there is the issue of cross contamination of their type of corn (conventional, GMO), with the open pollinated, organic I grow.
And you say don't save the seed, as it won't do any good...I use open pollinated Reid's Yellow Dent, which is an heirloom variety competitive in yield with most anything from Pioneer, etc according to the few field trials I have seen which have compared OP with hybrid.
Hogging it down is an option I have considered, as is baling the stalks, ears and all. But that presents me with management issues, also. Mainly that I need to gather them towards the house for access to water and electricity to keep water thawed, etc. My plan, as well, is to keep the feed in storage ahead of the hogs, if that makes sense. Bottom line is I think I need the availability of harvesting equipment.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 6:11am
I am old fashioned and I still like ear corn. The advantage of ear corn is no drying costs. Put it in the crib and take it out when you are ready to grind.
The disadvantages are that ear corn is a lot more work. It obviously doesn't flow well, so there is a lot more labor involved in the operation. Pickers, with husking beds, are getting hard to find.
Shelled corn is much easier to handle, but it has to be dried. Transportation and drying costs can add up quickly, if it has to be transported off the farm for drying.
Have you thought of harvesting high moisture ear corn with a forage harvester with a snapper head and a recutter screen and storing it in an Ag Bag? I know there is a lot more trash in the corn, but I can't see why it wouldn't work well for hogs.
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 6:28am
MoPete,
I pick with a NI 2 row, and run corn with our F2.  I agree with the previous post that the ear corn can dry on its own in the crib.  We then grind that for our cattle and horses.  However we let some corn stay in the field as long as possible so it can dry down naturally, as we have no drying facility on the farm.  We grind this for the pig feed to get the right protein contents.  My FIL is old fashioned, so ear corn gets ground for cows and horses, and shell corn gets ground for pigs and chickens.  It seems to work for us. But I am patient enough to finish the harvest late....Still have 40 acres out.
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 6:48am
I still pick some. If you decide to pick make sure you have some place that will buy your extra.
Life is simpler when you plow around the stump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoPete Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 6:51am
The extra labor is not too much of an issue as I am doing so few acres. But tell me more about the husking beds. I am not familiar with that.
Quote Shelled corn is much easier to handle, but it has to be dried. Transportation and drying costs can add up quickly, if it has to be transported off the farm for drying.
I think that would be very cost prohibitive for me, though likely a good option if I were planning for more acres across which to spread the cost.
Edited by MoPete - 29 Dec 2014 at 7:05am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoPete Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 6:58am
Originally posted by Johnwilson_osf Johnwilson_osf wrote:
MoPete,
Yes, I definitely can leave it in the field and let it dry. My harvest time will be so minimal that I should have no issues there. And I have heard nothing but good about the NI pickers.
Edited by MoPete - 29 Dec 2014 at 6:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoPete Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 7:04am
How long will it keep in a crib? That's definitely an issue although I suppose I could just buy more feeder pigs if I had extra. I really do want the feed ahead of the hogs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoPete Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 7:08am
Gerald J.
Never heard of that and I will definitely experiment with that. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 4:42pm
Corn will last a while in the crib.  We typically go through two cribs a year.  They are refilled each fall.  However, last year, we took corn out of a neighbors crib, that had been there three years.  The outside had been picked over good by the birds, but the inside was a clean and yellow as the day we picked it.
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 7:10pm
NI pull type corn picker (so you don't tie up a tractor forever).  It will store indefinitely if you have a good roof on your crib and pick it below 20%
Thanks
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 7:23pm
where in MO are you?
What is your budget?
Do you mind if the combine is a gasser?
I personally would keep an eye out for a good Gleaner machine, the 105 seemed a little crude in my opinion.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 7:32pm
DO NOT USE BIN RUN SEED OR OPEN POLLINATED SEED! Even a close out non GMO will out yeild either other option. You would be better off calling a few seed dealers and asking for their cheapest seed in your maturiy. Ear corn is ok if you do 10-20 acres 100 would get old quick. When my grandfather farmed he would pic two wagons first thing in the morning after milking. He then would slowly unload them to make sure he got every husk. In Missouri you should be able to get corn pretty dry in the field. My thoughts are get some sort F or K 100 acres with a K was not the end off the world. I have learned that the cheapest initial option can cost more very quickly. Hogs don't really like the extra ruffage from the cobs either.
LSilseth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LSilseth Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 7:59pm
100 acres of corn to pick is a lot. We do 10 acres with a one row picker and it takes two days to do:)
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoPete Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 8:01pm
I am in ne Mo, in Knox County and I prefer gas. There is a 105 a quarter mile from me I could get for $750 more or less, ready to change fluids and shell corn. I also looked at two JD270 2 row pickers at the same place. Terrible shape.
Edited by MoPete - 30 Dec 2014 at 6:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoPete Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 8:05pm
Do you have personal experience with OP seed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoPete Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 8:10pm
100 would be the maximum I would want to do. I have combined with newer equipment but not with what I can afford. I have never used a picker. How comparable would a two row picker be with a 4 row like a 105?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoPete Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 8:18pm
that was what I had in mind if I went the picker route. I don't see myself getting in too big of a hurry so I should be able to let it dry better than 20%. If I went the mounted route, how difficult is it to mount and ... dismount?
Post Options Post Options   Thanks (0) Thanks(0)   Quote LSilseth Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 8:21pm
If we had a two row I would do up to 50 acres but not 100. I hope you find what you are looking for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoPete Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 8:46pm
Thanks. I do too.
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 8:56pm
Mounting and dismounting difficulty all depends on make and model of picker and tractor. With a 2 row picker expect to do anywhere from 1 to 3 acres an hour depending on conditions. I enjoy picking ear corn but if you're using a mounted picker its a dirty job.
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 9:35pm
get a pull type picker if you are going that route. or a self propelled. you can still get most parts for the new idea pickers i know. the other thing to think about is to buy multiple of the same model so you will have parts.
Harvey/pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harvey/pa Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 10:20pm
I love to pick corn, I have a New Idea 2 row narrow picker (326) but don't pick much anymore. I would stay away from a mounted picker, They are wide row pickers and in case of problems or too much corn you might have a problem finding a wide head combine to shell the remainder if needed. The last couple of mounted pickers in the area stay on the tractor year round and as stated they are very dirty. I've had 4 New Idea pickers and 2 Olivers since the late 70's, the Olivers picked cleaner and shelled less but parts were harder to find. HTH...Harvey
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2014 at 10:36pm
Go with a pull type corn picker for now. If you have too much earn corn, just rig up a gravity wagon that feeds your JD45 combine. That way you could shell the excess. You could bin it or haul it away. If you are patient, you may find an older 2 or 3 row corn head & combine package deal at auction?? They usually go cheap around here.
How good does the Reid's Yellow Dent stand through storms during late fall & winter??
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 1:15am
OP corn is really making a comeback! I think there is a large dealer in MO for it as there are others across the country! they are trying to get away from Monsanto! and I think there is a pull type picker coming up at auction this week....i'm thinking in KS, will try to find it and let ya'll know! oh...and I've been thinkin bouts the OP corn too for this year!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 1:25am
o-k...found it...it's the jan 21st 2015 sale on BIGIRON.com...pics and descriptions under "harvest equipment"...3 dif units 2 pull type and one mounted with tractor. at Topeka, Ks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoPete Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 5:25am
Any idea about a JD227? I found 2 yesterday at a neighbor's. Pretty poor condition but so was all my equipment when I brought it home. So, maybe 20 +/- acres a day is a reasonable estimate? I assume that assumes the picker running full time with someone else emptying the wagons?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoPete Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 5:29am
Thanks. That makes good sense.
This page was generated in 0.254 seconds.
