H3 Steering Clutch Removal
dirtdobber View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dirtdobber Quote  Post ReplyReply Direct Link To This Post Topic: H3 Steering Clutch Removal
    Posted: 23 Mar 2010 at 7:58pm
I have removed the spring retainer from the shaft and ready to slide the shaft to the inside of housing but I have not been able to move the shaft any using the one hole that is visable.
Anyone have a suggestion as to my next step to try to slide the shaft out of the pressure plate and clutch assembly.
Thanks for any help.
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 9:26am
I have heard that heating it then pouring cold water on it helps loosen up the rust. Might try putting air hammer to it. Mine came out fine. Search previous threads, as there was one a month or so ago on this subject.
1961 H3
This page was generated in 0.971 seconds.
