175 cam in a wc
Clay2017 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay2017 Quote  Post ReplyReply Direct Link To This Post Topic: 175 cam in a wc
    Posted: 23 Dec 2014 at 3:01pm
Considering doing the 175 cam in my wc. What supporting mods do I need to go with this if any? How much should I pay for the cam? Where to find one?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2014 at 6:50pm
175 (gas) cams are about as plentiful as hen's teeth. There are some guys that will custom grind a cam for you. From what I have seen on here, expect around $250.00.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2014 at 7:00pm
You won't find a cam easily, get yours reground. A wd45 crank, 175 pistons, a wd45 carb, pertronix module and coil, or a magneto in tip-top shape. This will give your WC a lot of snort for not much money. You can go crazy but with a mild build like this and some good firestone 14.9x24 or 28" tires, you'll surprise those who spend more and think they need 38's to win.
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2014 at 9:24am
dont forget to have the carb re-built. i sent mine to  Motec Eng. tipton,in.for what its worth worth,i have run 28's  and now 38's-build the rims -run the big rubber.
