Still more generator questions. |
Larry in OK
Joined: 25 Jan 2010 Location: NE Oklahoma Points: 315 |
Topic: Still more generator questions.Posted: 22 Mar 2010 at 8:04pm |
OK, started of by reading what I could on here about troubleshooting generators and have had some success.
Initially I got nothing out of it so I took it apart and cleaned it up, cleaned up the armature where the brushes make contact and cleaned the grooves with a hacksaw blade. Now when I hit it with power it motors. My question is just how "energetic" should it be. It spins right up and runs smoothly but it isn't particularly fast and not much torque there. I don't know how strong the charge in my battery is so that may be part of it. Thanks for the help so far. |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34433 |
Posted: 22 Mar 2010 at 9:59pm |
That sounds about right to me. They don't spin real fast and not much in power.
gotta remember that it was designed to create electrcity, not to power something else.
Larry in OK
Posted: 22 Mar 2010 at 10:03pm |
Thanks,
I sure hope its good. For some reason I really want to keep it 6 volt but if it comes down to replacing the genny I probably going to go ahead and convert to 12V. |
ChuckLuedtkeSEWI
Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
Posted: 23 Mar 2010 at 6:25am |
The ones that I have that did test good motored up good, but like you said it doesn't seem like it is making alot of power. As long as it does it, you know that the generator is working and it's on to all the other stuff like wiring and cutout.
