645 payloader
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: 645 payloader
    Posted: 18 Nov 2014 at 2:53pm
Well, the 840 payloader I looked at last week I passed up. Just seemed pretty junky. Going to look at a 645 tonite, though. One issue with it, though , is the seller says that in lpw gear ot is just as strong as ever, but doesn't like to move much in high. Is this going to be a "don't walk away from it, but RUN!" Or will it still run a long time in low, or will that be soon to go out to, or is there some valve sticking that some marvel mystery oil may fix up? Any ideas? Thanks. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2014 at 11:40pm
Well,I ended up buying the payloader. I think I struck a fair deal on it, so that even if the tranny is beyond feasable fixing, I could probably get my money back out of it by parting it out. Still have to get it home. It's about 100 miles away. On my way down to look at it, I told my wife what the absolute most was that I'd pay for it. When I got to dealing on it, I asked the seller what was the absolute least amount he'd take for it. It was the exact same figure I told my wife, so I guess it was meant to be. Still open to advice on the tranny issue. Thanks, Darrel
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2014 at 4:33am
Have not had to go into trans on wheel loaders yet Darrel, but my 605 and your 645 both use Allison trans, so even if a rebuild is required, it wont be cost prohibitive
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2014 at 5:01pm
I am going to run this in the classifieds also, but I need a hood and radiator grill for this 645. Anyone know where there would be one? Thanks, Darrel
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2014 at 9:41pm
I've got a 545 that works well when it is just started but after getting warmed up, high range is barely useable.  Changed the oil and after putting in the amount specified, it wouldn't move.  Started pulling inspection covers and discovered the intake tube to the pump from the sump has a crack next to a holding bracket.  Put more oil in and it works ok but not great.  The only way to fix it is to pull the trans, which requires removing the engine after removing the hood and radiator.  Maybe if we have some nice weather in the next few months I'll be able to tear into it.
Sorry, I don't have any extra parts.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2014 at 9:52pm
John, is there any way a person could weld it with a small wire feed through the inspection cover? Darrel
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2014 at 10:23pm
I was just at General Gear.  (www.tractorparts.com)  He has a couple of 645s torn down, but I don't remember if he had a good hood or grille.
one54dodgetruck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2014 at 10:29pm
If I remember right the 645 had issues with the transmission pump getting worn and having low pressure. I think it was only around $600 in parts and could be replaced in the loader
Andrew
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2014 at 9:40pm
Andrew
   I'd be dancin in the street if that is the case. I'll have to check into it. Thanks, Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2014 at 10:56pm
Andrew
It might have something to do with a bearing in the oil pump
Here is a quick search of what im thinking
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
http://www.heavyequipmentforums.com/showthread.php?5102-Fiat-Allis-645-B&s=ff9d56d95b452375be4ef2874fe987ef
sorry forgot the link
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2014 at 12:30am
darrel, unfortunately the crack is in a place you can only see with a mirror.  I did think about trying JB weld but I just don't think it would work.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2014 at 12:34am
Mine had the same sort of issue, didn't want to go in high when you first shifted it. Turned out to be the linkage was worn, when you steer it from left to right after you shift the lever to high it would go...lol, and check to make sure the parking brake lever is all he way down, that affects the gearshift lever travel as well.
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2014 at 7:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2014 at 9:22pm
Well, I got the payloader home yesterday, and am slightly dis-appointed, as low and reverse aren't as strong as they should be, either. It will be useable, but is going to need some attention. I was going to add a gallon of Lucas oil to the transmission, but the transmission is already over-filled by quite a bit. Could be due to the same condition as John, CO mentioned above. What would be the detrimental results of over-filling by another gallon? The oil does look very clean, but maybe I should drain it and change the filter and re-fill it adding the lucas. Or could just drain it down enough to add the lucas and try that. If it comes to needing to do something drastic like a tranny re-build, who is the master at that? Any thoughts? Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2014 at 10:35pm
The main problem with overfilling is the trans builds up more heat and also can cause foaming.  Depending on what you use it for, you probably can get by this winter but come summer it will crap out on you after an hour or so of running.  If you take the cover off the left side (looking forward from the back) the intake tube is easily seen.  The bracket where mine broke is up above a few inches and with a mirror you can see it.  I suspect you will have to pull the trans out and repair it.  The good side of it is that parts are fairly reasonable and easily assessable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2014 at 10:54pm
How do you pull the tranny?My "new" 545B looks like the trans has to come out the back with the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2014 at 12:34pm
Now the dad gum thing won't start. Has like new batteries and starter, cables look good, has almost 13 volts, put jumpers on it also, and all I get out of the starter is the old clunk....clunk....clunk. It has always spun over to beat hell and started right up till this morning. Where do I start? Darrel
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2014 at 2:28pm
I  checked the literature on the 645 and they are 24 volt machines. The 545 is 12 volt. One battery will draw the charge from the alternator and leave the remaining battery low. Check your grounds. Most of the time that is the last thing people look at.
We have a large shopping center here in Eagan, and they guy is keeping the parking lot clean with a 645 Allis. She looks and sounds great and has been doing it for at least 4-5 years. They are a good loader even though they are old. These old machines will still be working long after all of the laptop repairable machines are melted into ingots and sent to China.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2014 at 4:19pm
24 volt system? I'd better check into that. I know it has two 12 volt batteries, and I thought they were hooked up in a parallel, but I never followed the cables that closely. I am going to have take another look. Thanks, Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2014 at 4:47pm
some one has converted it to 12 volts. Starter is stamped as 12 volts, alternator is 12 volt, and battery cables are hooked positives together and negatives together. I have the battery charger on it now, and I have 15 volts right on the starter. That almost seems like it is too much voltage, but still nothing but a clunk out of the starter. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2014 at 4:54pm
If its a Delco starter, the engaging solenoid may be bad.  With a heavy cable, jump from the hot post where the battery connects to the post on the starter bypassing the solenoid. I started our Cat 920 using that method until we changed the solenoid. Hopefully its not engaging because the flywheel teeth are bad.
Curt Anderson
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2014 at 5:21pm
If I understand you correctly, I tried that. I put the jumper cable + directly on the starter's hot post (not the solonoid), and the starter spun over, but the drive did not engage. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2014 at 6:57pm
If the starter spins, you have adequate amperage to energize the starter. Check the two small leads for continuity. This is a coil which pulls the drive into the teeth and energizes the motor. If it is open, then the starter solenoid will need to be changed. If you have
continuity, it may be that the plunger is sticking inside the solenoid. It comes apart. Polish it up and try it. You may end up putting a solenoid on it, however.
Curt Anderson
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2014 at 7:46pm
I am going to go with the idea that my solenoid has issues. I turned the engine over a little ways with a socket and breaker bar to make sure there wasn't a bad spot on the flywheel, and that didn't change a thing. So, I guess if I don't have to haul corn tomorrow, I'll probably be taking a starter off. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2014 at 8:04pm
Darrel, According to my shop manual it's just three steps to repair the transmission- Remove the hood and radiator, remove the engine, remove the transmission.
There you go, two, three days should do it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2014 at 10:57pm
Well I have part of the battle won already: the hood's off! Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2014 at 12:49am
To help keep the project on a positive note Darrel, they are a great loader, and as Curt said, they will be around long after all todays electronic control junk is dead and gone. While on logging trucks years back, many crews in the forests loaded us with 645`s. Some used Cat 950`s, and a few had IH loaders. The Allis was head and shoulders above the rest for lift capacity and reach. We`d arrive on their landings and skids, the 645 would grab our 3 axle jinkers, lift them clear of the truck bolster/stauntion, reverse out, line up the pole eye with truck coupling for us to drop the pin in, then with a couple of back and forward moves, stretch the pole out without us moving the truck, then start loading. In the time it took the 645`s to do that and have a bed of 40` logs on the bolsters, the Caterpillars were still stuggling with getting the jinker off coz the they didnt have the reach to get the pole over the truck stauntions - we had to drive forward for them. The IH loaders, well they were still carrying the jumper cables across the landing to get them started.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2014 at 4:12pm
Darrel: The solenoid is separate and will come off as it is screwed to the starter case with 4 screws. They are a very common item and should be available at NAPA.
Curt Anderson
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2014 at 5:52pm
solenoid was the problem. Don't have er back together yet, but hopefully tomorrow. Thanks for all of the help and encouragement from all of you guys on this project. Later, Darrel
This page was generated in 1.180 seconds.
