8070 Oil Leak
Eugene View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eugene Quote  Post ReplyReply Direct Link To This Post Topic: 8070 Oil Leak
    Posted: 21 Mar 2010 at 4:14am
I have an 8070 FWA with an oil leak between the engine block and the rear of the timing case. I have found that a couple of the bolts around the water pump have snapped off and fallen out. The gasket between the block and rear timing case cover is working its way out. I have been through the workshop manual and it looks like I can get the rear timing cover off without pulling the camshaft. All I have to do is remove the cam gear.
Is this possible ?  Is there anything to watch out for ? Can the gear be refitted to the camshaft easy enough ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2010 at 11:28pm
You have it right.The cam gear has a bolt holding it on with 1/2 of a 1/2 moon key.May not even need a puller to remove gear(can't remember) but it doesn't come off hard.Shouldn't be hard to reinstall. (Mines still apart)
Edited by SteveM C/IL - 22 Mar 2010 at 11:30pm
This page was generated in 0.067 seconds.
