AC B |
ACfanforever85
Joined: 02 Nov 2014 Location: north carolina Points: 12 |
Topic: AC BPosted: 10 Nov 2014 at 12:56pm |
Just put new resistor on to step down the voltage to 6 volts. I am still getting 12 volts to my coil. Not sure what could be the problem
ACfanforever85
Posted: 11 Nov 2014 at 8:10pm |
Anyone that might know what will fix my problem
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 11 Nov 2014 at 8:12pm |
Remove the coil and resister and buy a 3 ohm coil. Made to run 12 volts.
Edited by CTuckerNWIL - 11 Nov 2014 at 8:13pm |
ACfanforever85
Posted: 11 Nov 2014 at 8:15pm |
Do you think replacing the coil period, will fix my problem
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90808 |
Posted: 11 Nov 2014 at 8:19pm |
You apparently have a 12 volt battery and an old 6 volt coil. Just buy a new coil made for 12 volt system and you will be fine. The distributor and point don't know the difference. Old coil and resistor is a patch job, will cause you problems over time... just get rid of it now.
steve(ill)
Posted: 11 Nov 2014 at 8:20pm |
make sure the new coil says "12 volt with no external resistor ".
steve(ill)
Posted: 11 Nov 2014 at 8:27pm |
Your system now looks something like this ? Change the coil and resistor to one unit new coil. Edited by steve(ill) - 11 Nov 2014 at 8:28pm |
ACfanforever85
Posted: 11 Nov 2014 at 8:32pm |
Before I put the resistor on I had a ballast resistor and a 12 volt coil. The coil on there is probably 15+ years old
steve(ill)
Posted: 12 Nov 2014 at 5:51pm |
some coils say "needs external resistor" and some say "no external resistor needed..... for 12 volt systems.
