PLEASE don't kill me! LOL |
Dave in PA
Joined: 13 Sep 2009 Location: Mars/Wexford PA Points: 2631 |
Topic: PLEASE don't kill me! LOLPosted: 23 Oct 2014 at 6:21pm |
I was givin' a "green mower" today, Yes a deere, 135 lawn mower.
FREE for the taking, about 3 years old. NOW, I know that is has the rear-end problem, that is why I got it! Sooo, For the great info giving on here, what to do, look for, brain-power, fix, do, looking for ideas? Any clue?? If not, I just got a GREAT 22 hp B&S engine for free! Thanks, Dave |
wildbill26
Joined: 25 Sep 2010 Location: claysville,PA Points: 534 |
Posted: 23 Oct 2014 at 7:56pm |
Dave, I got one about 2 years ago to work on, wouldn't go.up hills at all, they said they put a new drive belt on, but put it on wrong, didnt have enough tension on the belt, my grandfather had one also, if you"loose reverse " the belt needs changed also, I would look at the belt before doing anything and it is kind of a pain to change also just to let you know
1950 wd wide front w loader
1940 b, 1939 m crawler |
Mrgoodwrench
Joined: 03 Apr 2011 Location: CHICORA PA Points: 2095 |
Posted: 23 Oct 2014 at 8:51pm |
I've seen the pulley strip out on the rear end
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25269 |
Posted: 24 Oct 2014 at 7:00am |
Dave, does it have a 'Tufftorque' Hydro unit in it ??
If so it CAN be fixed IF it still kinda goes forward and backwards. Cost is $25 plus 2 cans of SYNTHETIC oil. Labour is 'free'. 1) remove hydro from rider.... 2) turn upsidedown to drain...for 2-3 days 3) order 'kit' from tufftorque..oops should have been #1. 4) CAREFULLY remove steel bolts from aluminum housing, I did say CAREFLLY( yeah, I broke 2 bolts off....) 5) cleanout any crud, wipe shavings off magnets,etc. 6) install the 'kit' ( metal holder and 2-3 magnets) 7) gasket seal the housing and button up 8) on bench fill with SYNTHETIC oil 9) Purge hydro FOLLOWING tufftorque's paper 10) reinstall into rider 11) Purge hydro FOLLOWING tufftorque's paper again 12) drive it out of shop and have fun. The JD hydro's are below Tufftorques specs. NO drain plug Uses 10W30 oil NOT synthetic Fewer # of magnets,in wrong places too hope this helps,PM if need more info. Jay north of the 49th |
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 24 Oct 2014 at 8:10am |
Hey Dave, if its to costly to fix the rearend, like you mentioned, you gotta' nice 22HP Briggs to toss in an Orange Tractor! Sell the chassis to some Green guy.. LOL!
Ethan Souerdike
Posted: 27 Oct 2014 at 9:18pm |
AHHHHHH!!! Send it back to the deepest darkest corner of the earth where it crawled out of!
If the women don't find you handsome, they should at least find you handy.
