Power Unit |
GaGoober
Topic: Power UnitPosted: 17 Mar 2010 at 6:39pm |
I just purchased a A-C Power Unit and am trying to find out its day of manufacture, etc. Can anyone tell me anything about it or where I might find some info on it.
SN: CE 47018 K
Thanks
Mark
R Aiken
Posted: 17 Mar 2010 at 6:57pm |
Should be a 1945
Ken in Texas
Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Posted: 17 Mar 2010 at 8:17pm |
Check the AM casting number. As a general rule BE and CE blocks cast in 40 ended in 12. 41 a 13. 42 a 14 and so on. That K in the SN means it was a dual fuel unit and would run on Kerosene
Sam T-Ga
Joined: 13 Sep 2009 Location: Monticello, Ga. Points: 392 |
Posted: 18 Mar 2010 at 3:58pm |
Goober, what part Ga you from? I am in Monticello. Sam T-Ga.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 89156 |
Posted: 18 Mar 2010 at 8:15pm |
you know the CE motor is a 125 cubic inch and was also used in the model B, C and CA tractors.
DREAM
Joined: 06 Jan 2010 Location: Elberton,GA Points: 1828 |
Posted: 18 Mar 2010 at 8:29pm |
Hey Goober, welcome to the forum. I'm from Elberton, GA. Mr. Sam, how you doing?
Also, if you need a hood for that distillate power unit, I have one. It's currently doing duty as the hood for my C. I'd rather have the right hood for the tractor. Send me a message or call if you need it, or just want to talk about tractors. 706-498-0363.
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 18 Mar 2010 at 8:31pm |
I agree with Richard. Probably mid 1945. There is no way to tell what month or day it was built. Here is Bryan Smiths web page with a lot of information.
http://people.clemson.edu/~wsmth/SNFind/esn_tsn2.htm |
GaGoober
Posted: 18 Mar 2010 at 9:39pm |
Thanks to all for your replies. From info I've gathered here and some other places I was able to find the units serial number. It is on the stamped plate riveted to the clutch inspection cover, SN: PU 28740. Not sure if that helps on the manufacture date or not. I have shot some PB Blaster all over it and I pulled the valve cover off, all of the valves seem to function OK. The exhaust manifold is shot. Who has the best parts and pricing ? My Palmetto is south of Atlanta , north of Newnan and west of I-85.
Dream, I may call you about that hood but first I'm going to try and get it running.
Thanks
Mark
morton(pa)
Joined: 11 Sep 2009 Location: Lancaster, PA Points: 1234 |
Posted: 18 Mar 2010 at 9:47pm |
Be careful. May want to look that manifold over carefully before you replace it. If it was a duel-fuel manifold and you plan to try to run it on kero at all, make sure you get another duel-fuel manifold.
