OK,,winters almost over, who completed projects ?
LarryWC In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Topic: OK,,winters almost over, who completed projects ?
    Posted: 14 Mar 2010 at 5:44pm
So I saw a thread last fall here on what some would be working on while the snow flew.
Anyone have a completion or an update?
Me?,,,well I WAS unemployed  (for 14 months!)so that put the skids on any money spending,,,however,,there's a happy ending to MY winter!!!,,I just secured employment and now have a GOOD job!!!
Just went through orientation last week and will start my job actually working tomorrow morning!!!
www.allischalmersmuseum.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 5:59pm
Congratulations on the new job. My project for the winter was to get the 35WC hauled to somebody who could complete it for me. I think he has everything except the fenders and fender brackets. I hope to see it run early this summer.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 7:04pm
My CA got new brakes, pinion seals, and the handclutch cleaned. Also replaced the beat up hood with one that was not nearly as beat up. Its ready for work this summer.
My 2nd D12 rehab got new brakes, pinion seals, electrical system O'haul, rebuild the upper steering gearbox, new seat/battery box/rockshaft frame, rebuilt pivots for the rockshaft and a new aftermarket seat. Put it away for better weather. Its now back in the shop to get a head O'haul, hang on a nose weight, and get the rear fenders fabbed and hung. Should be ready to pull a plow and disc by the time the frost and water in the ground is gone.
My D17D got a new inector line, freed up eccentric locks, and new tank heater. Its ready for work also.
Also put an additional 1,100 miles on my snowmobile and went to Mexico fishing for a week.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 7:48pm
Good luck with the new job Larry. I was laid off for 7 months myself and just got back to work 6 weeks ago. I managed to put a new stereo & speakers in my 6060, that was about it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 8:11pm
Thanks guys!,,what even BETTER?,,,the safety guy has a restored WD45,,and is an Allis fan,,(he WILL be at Dale's this summer),,the guys in the control room?,,one has a D17 and is restoring it,,TWO of the mechanics are Allis fans and have WD's,,one has an Oliver 77 too,,,it's like not only did I get a great job,,,I also landed in Allis heaven!!!!!!!!!
ac_bowsers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_bowsers Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 8:30pm
Got the 1935 WC carb problems solved,plus touched up the wheels on it. Checked over D17 puller,had to get new battery for that. Detailed and serviced 8070. Plus restored a 1949 G,its about 97% completed, just need to finish up wiring for tail light and rebuild headlight and make wiring for it. It will be at Sublette next Sunday with or without headlight!!
Pine Stock Farm "Home of the ALLIS" 35-WC-36-U-37-UC-47-C-49-G-57-D17-58-D17puller-63-D21-71-210puller-79-7045-83-8070-AA9675-BigTen-B10-310-1300fieldcult-snapcoupler imp.-longhopper blower,signs,etc.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 8:57pm
   Don't think I finished any,    BUT I started a lot MORE!!!!
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 9:02pm
I never finish anything. I told my wife that way when I die and she finds a new man it will give him something to do. I don't want the new guy just sitting around watching tv all day.
This is a saying I never tried:
If you do today what doesn't need doing
When it does need doing
It is already done.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 9:52pm
I planned to put new bearings, seals and brake bands in the rearend of the 37 WC, only managed to get one axel done.  Got most of the gaskets made, could do that in the warmth of the house.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 10:04pm
I'm with Allen, got another project on the go now too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 10:14pm
I just finished my $3 Wisconsin AKN small engine today. It only needed a valve job and a carb kit. I picked up an ACN that is good bug repellent at the same auction. I just found out I can get a rigid hone for small engines so the ACN and an ABN are both going to get new pistons fitted next week.
Dale H. ECIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale H. ECIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 10:27pm
 Congratulations on the new job Larry. I have to confess I have not done very much this winter on tractors, I did get started on the High Crop B but a long way from finished, oh well I have 4 months!!!!!
  I have been cutting fire wood all winter, my son and I both put in outdoor wood furnace boilers last fall.
Allis Chalmers Museum, Paris, Il.http:// www.allischalmersmuseum.com 217-275-3428
John In. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John In. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 10:57pm
 I put new siclebar on 80R mower along with new bearings. Took apart aircleaner on WD45 and cleaned the wire mesh and put it back together, fixed head lights so they stayed tight in their mounting points, had to do a little welding on the mounts to fix cracks.  Replaced broke leaf spring on old ford pickup..      John
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 11:25pm
We had a mild winter and would have been a good time to get a lot of repairs done, but I ruptured a disc in my back in November that pretty much took two months out of my winter to heal. Fortunately I got better without surgery. I did get a 175D  set up for my new tilling tractor and started parting out the 170D that it replaced.  I also volunteered to help get a new "farm to school" program started in our school district and it has taken a lot more of my time than I anticipated.  Now I just need to get a few oil changes done and a couple of greenhouses put together....
ALLIS EXPRESS!
This year:
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 1:20am
Well guys not a big fan of the cold so i dont have many winter projects (dont have a good shop but need one BIG TIME) spent last summer re-doing and "costomizing" a 7080 and the summer before re-doing my WD-45 (had 9 days in it) ive been wanting to get pics on here but the 7080 pics are too big il get some for ya i think you all will like my 7080 il bet anyone its one of a kind its on youtube (before and after) if ya want to see it my 7060 is too send me a pm il tell ya how to get there. I just realized a buddy figured out how to put some pics of my 7080 on here its under "Dans sweet 7080" hope you all enjoy them
Edited by Dans 7080 - 15 Mar 2010 at 3:29am
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 5:44am
Made lots of progress on the barn project and actually have done some minor repairs on the SC blade that's hanging on the back of the D14. Right now the C is in the shop getting brake housings emptied (mice, etc), carb rehabbed (float valve leaks) and gas tank replaced (neighbor's tree fell on it). Then it'll be the CA's turn...... Like Eldon I've been slowed down with a disc problem in my back; surgery may be soon.
WC, CA, D14, WD45
acisbest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acisbest Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 6:52am
After about two years of sitting in the middle of my small barn I got my CA running again... I put on the full carhart suit and braved the PA cold. It was a long haul... Self ground the crankshaft with a winona in-block grinder and bought a rebuilt kit as my 2009 xmas present, sleeves, bearings, valves... About 2 weeks ago I got it running and drove it out of the barn, boy its nice to have that space back... Many more things to fix on it but at least its mobile.  And now I can get my C out since the CA was blocking it. So, it was a succesful winter. I think this is it for tractors, 6 is the limit and one dozer...
WC,C,CA,WD,D17,HD6G
ernie (ECIN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ernie (ECIN) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 7:01am
Well, I wanted to work on the WD, but the wife decided the bathroom remodel was more important! Needless to say, the WD never got in the shop, but the !##@$@!%^^ing bathroom is done!
allallis2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allallis2 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 9:14am
My buddy and I worked all winter restoreing a 55 G for me and a 55 wd 45 for him. Had them both apart at once in the shop. Pretty cool to have two Allis's apart at once and bring them back to better then new condition. Made prime and paint go easy. We could paint some of my parts and some of his all in the same day. Mine is 98% done and will be at the sublete show sunday I hope, my buddies is 95% done, need new fenders for it and a good set of rear tires. Hope to restore a B this winter that belongs to my grandma.
1955 G,1938 wc unstyled, 1938 A 1938 B, 1949 G
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 10:18am
Larry,So glad you found something but like you said AC heaven. Know about not having a job. 1/09/2009 mine went to Mexico. Good luck.
"Burgie"
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 12:03pm
Well...I've bought a few more projects to do and bought parts for the ones I had before I bought the other ones...so,does that count? Can't say that I've accomplished anything yet! LMAO!  Rick
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 12:18pm
cool your jets!! we hav'nt even had the high school basketball turnyments(sp) yet, if more snow is had, it will be a blizzard during turnyment(sp) week
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 1:20pm
Didn't get anything done but sure was fun seeing what others did during the winter such as Brian's D19 Diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 2:25pm
Ernie, I'm a little in the same boat as you. I want to insulate my shop so I can have some heat in there, getting $1700 back from tax return. Wife wants to pour our basement floor. (It's dirt now) My thoughts are it's been dirt for a little over 100 years, 1 more year won't hurt...
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 4:49pm
might need to let the wife win that one. it will save you money in the long run. I gaurantee she remembers the 383 engine build. they are not forgetful creatures.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 7:38pm
I have to agree. Compromise is the best investment you can make. They don't forget ANYTHING........EVER!
The christmas blizzard I tried to blade out. A complete waste of time because I didn't have chains and a 1/2 inch of ice under the snow. I have done it a hundred times, but I have a hill with 20' drops on each side and sliding down backwards made an impression this time.
Chains practically fell in my lap "free" and very good chunky ones. I had to make them fit,
but hey, free versus $500, I can put in a couple of hours.
Saw the manifold is really crap. Got a new one. Haven't changed the fluids in awhile. Did that. Fixed a few leaks. Put brakes on it. Didn't really need it but did it anyway.
got the 3point in alot better shape for brush cutting.
Plugs, wires, cap, etc.
Then decided I needed power steering.
Found that, got it on. Works beautifully.
I have a different tractor now.
All I need now is a front end loader.
I'm working on it slowly.
Anyone has one for sale for a WD, let me know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 8:15pm
She says I have too many projects to do now. If the environment were a little more friendly, they would get done sooner. Yep that's my story and I'm stickin to it...
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 8:40pm
Two weeks ago, the Mrs & I took a trip to Ia & MN via St.Louis, KansasCity, Omaha, SiouxCity, SleepyEye, NewUlm, Nicollett, then back through Waterloo,IA QuadCities, Peoria, and then back home.  One big loop.  We stopped in Paris, IA and picked up a sweet 433T engine off a gleaner combine, then stopped in Hector,MN for a set of planter Ausherman Terra Tine row cleaners.
It was a great getaway for us from our Illinois winter blues.  It was a very a beautiful drive up the Missouri river bottoms & loess hills.  MN had a huge amount of snow - most I have ever seen.  Some rural snow drifts were 10' tall & 30-40' long!!  New Ulm, MN has great local brewery - August Schell Brewery.  We took the tour and bought a few cases to bring home.  Also, it is a great town for German Food..  Stopped in Nicollett, MN at Schmitzs meat market and picked up a basket of meat sticks, summer sausage, & brauts.
My son was home from college last week for spring break.  Together, we redid our AC 706D ignition system.  New switch, starter, battery cables, & 2 batteries.  It now starts when you turn the key - Yeah!!  Best part - good talks with my son about college basketball & about some of the girls that he has been dating.  We also drank a few of the Schell beers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2010 at 4:11am
WOW!,,looks like alot of you had a fairly busy Winter!
Edited by LarryWC In - 16 Mar 2010 at 4:11am
StanOhio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanOhio Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2010 at 5:30am
Put air cleaner on D10, fixed rear tire on 7010, put an MTD snowblower on AC917, rebuilt 3 marsh pumps, split some wood, didn't get the Farm-All 460D overhauled yet, or the WD45, oh, I plowed snow, put ball joints in my 350 super duty. Helped dad put engine back in Jeep. Got 3 or 4 sinus infections. Fixed a couple water leaks. I'm sure I forgot something.
This page was generated in 0.223 seconds.
