Sandblaster, What To Get?
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: Sandblaster, What To Get?
    Posted: 24 Aug 2014 at 1:24pm
 I'm thinging about getting a snadblaster to do big jobs like tractor frames and wagons. I already have a cabinent type for small stuff. What do you guys recommond?
Thanks & God Bless
Dennis
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2014 at 1:30pm
I recommend the siphoning blaster from tractor supply. Cost $100 and works great. Just make sure your lines are clear of moisture and your sand is dry. Love mine.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2014 at 1:50pm
The wind maker is more important than the blaster.Make sure you have enough cfm's and dry air. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2014 at 3:13pm
LOT"S of CFM's
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2014 at 3:57pm
I did some rear wheels with a TS blaster. It worked well. I also bought their blastng media.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
beaud_250 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beaud_250 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2014 at 8:46pm
Man I was just thinking about posting the same question. I'm looking for something to mainly sandblast my wheels. would you guys recommend a pressurized blaster or the gravity feed from Tractor Supply?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2014 at 9:00pm
I have a 10 gallon pressure tank style blaster from Harbor Freight. It works quite well. A pressure tank blaster will be more aggressive than a siphon type. Tracy's right about the air source. Sandblasters use LOTS of air. I have a pair of 3hp 60 gal compressors and they will run my cabinet blaster or the tank blaster as long as I want. Having clean dry sand is a must too. The only gripe I have about the tank blaster is it won't work with Black Beauty blasting crystals. They just don't flow as well as white sand requiring constant agitation of the tank to work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2014 at 9:02pm
For blasting heavy rust, you want a tank style. Siphon units don't have the velocity a tank does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2014 at 9:42pm
Getting enough air is a problem. I just can't get enough to really do a fast enough job. I think you would need a big compressor. I have tried using my average size compressor and I think I could use two or three of them hooked together! I have thought it would be nice to have something I could hook a tractor up to that would move lots of air!
Where do you guys get the sand?
Do you recyle it?
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2014 at 9:44pm
I get mine at Lowe's. Black beauty
Can't fix stupid
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2014 at 9:54pm
Hello Dennis    I would recommend finding a used pressure type one most parts are available. You will need a compressor 20+ CFM. I use about a pallet of black beauty every 2 yrs.      ps are you going to Pontiac next week??? we'll be there Allen
ACFarmer86 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer86 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2014 at 10:02pm
We use a pressure pot, 200 lb capacity and a diesel powered air pump for doing all types of jobs, even works ok on tin parts like hoods if not get too close. I think the brand is clemco. Takes a lot of dry air like the other guys say, we also use a fresh air mask for better viability and safety. Just the blaster is few thousand tho.......
Grandpa's 1953 WD, D17 series I, 190 XT III
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer86 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2014 at 10:04pm
Forgot to say we use black diamond on tougher blast projects and silica sand o the easier stuff. Hope it helps some
oldways View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2014 at 10:35pm
I think I got mine at tractor supply also. I also use black beauty. I sweep it up and put it through an old window screen and reuse it several times. Like others have said gotta have the airflow. I'm in the middle of blasting my WC right now. Bought mine few years ago when I restored my G started out with a wire wheel on a grinder didn't take long to figure out I needed a blaster.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2014 at 11:08pm
Hey ACFarmer,,,I'm glad you mentioned using the fresh air mask, when using "SILICA SAND" or "sand blasting sand". Silica sand is very dangerous stuff to use as a blast media as the silica dust is Bad Stuff to your lungs.
   Silica sand does work good in cabinet blasters but you must wear a respirator and have an eductor or dust collector to collect all the air borne dust it produces.
Hope this helps.
Boomer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boomer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2014 at 11:10pm
I have the siphon feed, pressure tank, and power washer attachment. I like using the power washing attachment. It does a great job, and is more healthy (you don't breathe the dust). I think I got it from Northern tools.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2014 at 11:10pm
Do you recyle it?
I've been getting silica sand at Menards. I've been intending to sift the used sand for reuse, but so far that hasn't happened.
nanuk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nanuk Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2014 at 2:57am
silica sand grows wild in northern Saskatchewan
AC7060Pd 1975
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2014 at 6:02am
I am a hobbyist.  I use the pressure pot (think it is the 80 lb one from harbor freight and get along OK, except for the extremely high humid days like right now in the midwest.
My 11cfm at 90 compressor is what I consider minimum for that blaster.  Hot air from  the compressor is a killer for me.  It carries the water in vapor form until it hits the nozzle.  I found a second 80 gallon tank that I run the air into from the first 80 gallon to help dissipate the heat.  Also keeping a big adz fan on the tanks and compressor seems to help a lot.  Black Beauty is for me, but it is fairly aggressive.
Before using silica sand search up on what that stuff will do to your lungs, and that process is pretty much not reversible
I sweep up the concrete pad and sift the used stuff back i the tank while adding about 1/3 new to the mix.
Found that even new black beauty right out of the sack needs to be sifted.  Screen wire size works for me.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2014 at 6:17am
Here is a little tip to kill the water in air from a hot compressor. Take  a 5 gallon bucket, fill it with cold water, coil 50 ft. of air hose into it. hang water separator over edge of bucket on end of hose . Hook up and use, no more water in air.  Dave. Father of poor necessity.
NDBirdman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2014 at 9:21am
My compressor is a 174 psi/5 gallon sears black oil-less compressor.  I picked up the Black Beauty from TSC.  Worked good, but I had to stop quite often as the compressor could not keep up.  Got the job done on a couple small rims but it took a long time because the air could not keep up.  I laid out a 12X12 tarp and sat in the middle of it for sand blasting, made recovery of the media painless and quick.  Go with the biggest compressor you can get.  I wore a mask and goggles.  When I was done, *I* had sand in places I had forgot I had... LOL.  Long sleeves and no shorts!  High top boots.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2014 at 9:37am
I've got three small compressors all connected together.  I think they are two 20 gallon and one 30 gallon tank.  They work good as a team.  Go team! Big smile
I run the air through an air/water seperator and then through a desiccant to dry the air.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2014 at 10:06am
Yeah, water vapor is a problem. Both of my blasters came with water traps on them and I leave the drains cracked so any water collected drains as it forms. Seems to work good enough that I never have any water related problems.
Both of my 60 gal compressor tanks get pretty warm after a while. I put a good sized fan on the pumps if I know I'm going to blast a lot.
Edited by Brian Jasper co. Ia - 25 Aug 2014 at 10:07am
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2014 at 12:33pm
In the cooler weather, I blast and coat condenser tube-sheets on HVAC chillers.  My set-up is a 1.5 cu. ft. Schmidt blast pot and a 185 CFM Joy air-compressor.  The media is Black Beauty 12/40 grit.  The result I am after is a near white 3 mil finish.
This is TOO HARSH for doing tractor restorations.
If using Black Beauty (Diamond Blast), use the extra fine.
My suggestion is to rent a compressor and blast pot from a rental store.  You will also need to determine the size and variety of blast media, for your project.
http://mcfinishing.com/resources/blastingtech.pdf
http://blastech.com.au/wp-content/uploads/2011/05/spread.pdf
http://www.canfieldjoseph.com/abrasive-blast-media.php
http://www.nortonsandblasting.com/nsbabrasives.html.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2014 at 7:45pm
Got tired of waiting for shop compressor to build air so I built my own blasting compressor.
http://www.allischalmers.com/forum/forum_posts.asp?TID=56435&KW=air+compressor&PID=441922&title=compressorplan-b#441922
http://youtu.be/Yee81h_73k4
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2014 at 9:58pm
DonDittmar,
VEry nice outfit you made there. Where did you get the compressor cyliner part of it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2014 at 9:09am
WOW, now that's a compressor Don!!
Edited by NDBirdman - 26 Aug 2014 at 9:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2014 at 2:22pm
Two parts, to just the air side; volume and air quality. Whatever you have for an air compressor, go with the biggest tank you can. You will need a compressor to fill it, without the compressor hurting itself by running constantly. CFM does the work so unless you are doing very small jobs, you will be waiting on a compressor that is running itself to death. Lower volume/pressure to work with and you will get frustrated when you "outrun" the compressor. Tanks are cheap and set up with the right compressor, they make all the difference in the world.
Tanks are also a large separator; impact separation and to an extent, a larger area to cool the air, allowing the liquid entrained in the air to fall out.
Compressor sized to the job.
Tank sized to the compressor/max output of what you want to do.
Auto drains; both on the receiver tank and water/particulate/oil removal filters, essential if you want very clean dry air.
If you are running a recip compressor, expect 100ppm oil carryover and this only increases as the compressor ages. No aftercooler on the recip unit, expect hot, water laden air that must be "treated" for quality. With an aftercooler (not intercooler), you can get the "approach temp" of the air down to within 100 degrees of ambient; this is the air temp as it leaves the compressor. A refrigeration unit will drop the air temp which allows more water to be able to be removed. I set up many air systems in factories, body shops, etc. and it all depends on what you want to do with the air; 10 - 1000+HP, you still have to set it up to do what you want efficiently.
The old rule of thumb; a 100HP compressor, set at 100 psi, running at 100 degrees ambient and near 100% relative humidity will make over 20 gallons of water a day.
Many times I received a call to come out and quote a new compressor only to add up the required cfm to find the compressor unit still had 20-30%+ capacity that just was not being used properly. By tieing the dead ended piping together, installing a 240 or 400 gallon receiver tank furthest away from the compressor source and showing the customer how to install proper drip legs at points of use, they quickly realized they did not need another compressor. When they did expand operations, I got the call and they had the luxury of already having the air piping/storage in-place.
If you want to do plenty of pieces constantly, and even bigger jobs if you are seriously getting into blasting, hard to beat a pull behind 180-200 cfm diesel unit as it can also be used to do many other things. It will typically be a rotary screw (low oil carryover compared to a recip), have a separator and designed to run flat out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2014 at 6:22pm
Pump is an Eaton, made in Eaton OH. You see them advertise all the time on the tractor pulls on RFD. At the time I bought it, it was the biggest recip they made at 42 cfm. They now make biggers one, up to 98 cfm I think. Compressor is controlled by a standard D2 governor found at any heavy truck shop. The compressor unloads at 120 psi, which helps in keeping the pump cool. In the unloaded mode it draws in air and pushes it and heat right back out.
Tank is 120 gal propane pig. Take had been empty for years, but took awhile to get the perfume smell out
Hose reel is 50 ft from TCS.
Engine is of course an Allis B power unit
http://www.eatoncompressor.com/catalog/item/518643/1320611.htm
1968 D15D,1962 D19D
