Gleaner A2 finally running
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner A2 finally running
    Posted: 12 Mar 2010 at 2:32pm
I have finally got my 64' A2 Gleaner running.  I bought a 262 engine out of an early F from my parents neighbor.  It ran good, just needed to be mounted to the A2 engine cradle.  Once I got it mounted to the cradle (which I painted while it was off) I was able to use a forklift and mount it to the combine.  I did have to adapt the fuel line as the two carbs were slightly different.  I also used the rotary screen (in front of the radiator) off of the F as I believe it will work better in corn.  Finally got it all wired up, fuel lines mounted, filled coolant, and fixed batter cables I got it to run.  Two nights ago I was able to drive it under its own power (probably the first time in 10 years it had moved under its own power).  I just got one hydraulic line repaired (from pump to header) so hopefully I can get the 240 corn head off and switch it to the 330 head.  I also plan to pull the cover off of the threshing cylinder and have a look see at the cylinder bars.  I may end up turning them around if they are wore too bad.  I am planning on giving it a workout this fall on two patches (one 4.5 acres, one 5.5 acres).
Adam
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 6:17pm
Adam, Good to here the A2 is up and going.
I had to put wheel weights on my A to keep the steer axle on the ground with a 330 head on her.
I used WD front wheel weights on mine.
Don
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2010 at 8:59am
I like seeing the old Gleaners still going too.  Great job on saving this one!!!
