WD front pulley on a gleaner conversion
twarner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twarner Quote  Post ReplyReply Direct Link To This Post Topic: WD front pulley on a gleaner conversion
    Posted: 12 Mar 2010 at 11:44am
In adapting the WD front pulley to go on the Gleaner motor, it looks like the pulley will not go on far enough to allow the bolt to go into the hole in the crank. Every conversion I have seen moves the hole on the pulley to match the crank...however can one just machine out the front of the pulley to allow it to go on the crank and match the hole already in the pulley and crank? Clear as mud I know but I hope you guys know what I'm talking about...
Terry
TYLER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TYLER Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 12:32pm
We generally machine the pulley out to match the original holes. It doesn't take much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote twarner Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 12:41pm
Thanks, That's what it looked like to me, but I thought I would ask the experts here on the list!
Ohio Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ohio Orange Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 12:45pm
If you use the original hole in your pulley your belts wont line up. Once you have the bore opened up to fit the crank, you'll need to relocate the hole in the pulley. I think it was 7/16th's or a half inch off on mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TYLER Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 1:56pm
Are you using the water pump off of the WD? If not you will need to. just drill the holes out in your pump to fit the bigger bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote twarner Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 2:27pm
Yes
water pump, flywheel, clutch off the Wd. Going to use the Gleaner gov assembly as well.
Terry
GT in Indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GT in Indiana Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 6:17pm
That is exactly what I did.  A local high school did it for me in their machine shop.  You will no longer be able to start it with a hand crank though...
1955 WD45 we like to call Ruby
