Wd45 won't start
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 won't start
    Posted: 01 Aug 2014 at 8:42pm
Rebuilt starter and it is now switched from 6 to 12v.
I replaced coil/points/condensor and rotor .
I was wanting to switch it also to neg ground but not getting power to the coil once switch is on.
It will really crank over very fast but no spark. It still has the gen but not connected. It will start if I crank it then touch the gen wire to the starter but shut off once I remove that wire .
What am I missing?
Looked at my cousins d15 and his I400 both are 12v neg ground
if farming was easy everybody would be doing it
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2014 at 9:13pm
When switching to neg ground the wires on coil need switched and so does amp gauge. Sounds like coil is gettin power from generator ?? Should be the on position on key switch.   Shawn.
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2014 at 9:23pm
Cousins two tractors are wired different at the coil but both work.
I ended up switching it back to pos ground and got that result. Neg ground I had nothing.
I was wondering if I had to wire the gauge different
This page was generated in 0.071 seconds.
