Which model to choose?
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Which model to choose?
    Posted: 28 Jul 2014 at 11:06am
If you were going to pull a vintage AC in 3500/4500lbs, what is the favourable model and set up? Thanks!
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2014 at 12:36pm
WD or WD45 excels at those weights.
Charlie
bigcountry48 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2014 at 1:01pm
Wd45 all the way! Can't be beat in my opinion.
1950 B, 1952 pulling wd, and 1954 wd45
pohlman249 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pohlman249 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2014 at 1:35pm
Wd 45 or late wd so you can swap the d 17 ring and pinion in if you're area has a lot of tough h farmalls with corn picker gears and 18.4 38
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2014 at 6:54pm
I assume the D17 rear end slows it down?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote pohlman249 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2014 at 6:08am
Yeah same ring and pinion as 45 diesel
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2014 at 6:25am
How light can you get a d17 without using aluminum everywhere?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2014 at 6:58am
Old 1957 D-17 with cut 15.5 x 38's and D-15 NF still has hand clutch, PTO and hydraulic pump, weighs in at 3750 lbs to 3800 lbs with no driver and no aluminum. Seat frame, fenders, lift arm housing assembly, all snap coupler bell/OEM bail/drawbar, power steering and generator all gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2014 at 7:21am
Just thinking if you could get a d-17 down there you would also have a power director if you needed it for a little more gear selection.
Hudsonator View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2014 at 8:12am
I'd vote WC.
Much lighter, much simpler, and same engine options. Many more weight options in terms of honing in how much weight you need and where.
I never found the handbrakes to be a problem, who uses both at the same time during a pull?
There isn't much a WC can't do.
WD's just do it better.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2014 at 9:24pm
WC
allismanamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2014 at 4:30pm
My 37 WC put many 45s and h farmalls to shame for the simple fact that I could put 500 pounds of weight on where most guys where not able to put any weight on
They lifted and spun out
Where my WC nose stayed down and dug in for the win
~AMP~
