CA Motor Rebuild |
Tom IL
Joined: 11 Sep 2009 Location: Marshall, Il. Points: 26 |
Topic: CA Motor RebuildPosted: 05 Mar 2010 at 7:31pm |
Putting a CA engine back together, wondering which way the wrist pin lock bolt faces and the torque on this bolt? Any information will be appreciated.
Thanks.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90812 |
Posted: 05 Mar 2010 at 8:39pm |
connecting rod bearing (crank end) is thicker on one side than the other... the rod is offset from the bearing.. rods 1 and 3 have the thick side of bearing toward the back- flywheel end... rods 2 and 4 have the thick rod side facing the front- fan end. Rod cap bolts are 25 ft pounds... dont know that i ever read what the pin clamp bolt torque was. I just put them in "tight".
Ken in Texas
Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Posted: 05 Mar 2010 at 8:52pm |
Here is what my Manual says
Assembly
The con rod is offset and the piston bosses are of equal length. To assemble connecting rod to piston, centralize the rod between the piston bosses and the pin in the piston and clamp securely. To assemble the piston and rod to the engine, the long offset side of rod must be turned away from the nearest main bearing.
That all it says and then goes on about rings, bearings, shims ect
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 06 Mar 2010 at 10:24am |
![]() If you look at the wrist pin in the picture you can see the same amount showing on both sides of the rod. You will only see wrist pin on one side of the rod if they are in backwards. Nothing beats using your eyes and watching what your are doing when assembling an engine or anything. 35 to 40 foot pound would be all you would need. If over tightened they can cause the rod to fail. I don't use a torque wrench on those bolts. Just one hand tight with a 1/2 ratchet which would be very close to the above. Edited by Dick L - 06 Mar 2010 at 10:31am |
Tom IL
Posted: 06 Mar 2010 at 4:32pm |
Thanks guys it finally soaked in. I was missing the rod offset. Hate to say how many times I've read the book. I rebuilt a B few years ago just can't remember anymore, thanks again.
