wd noise when razing 3 point
Ronnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Topic: wd noise when razing 3 point
    Posted: 21 May 2014 at 11:23am
I have a wd that makes a graling/ gear nois. it only does it when u rase the lift arms it's not jumpy or low on fluid and it will pick the 2 bottom plows out of the ground fine, it doesn't do it when it is razed all the way up gust when the arms move up . is this nois normal
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2014 at 1:02pm
The hydraulic pump makes noise when lifting, yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2014 at 4:03pm
Ok just won't ed to be sure
