Allis Chalmers 170 gas engine?
AKA.ON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AKA.ON Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 170 gas engine?
    Posted: 04 Mar 2010 at 9:09pm
Does the 170 gas have the same engine as a D17 or a WD45? If not what are the differences?
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2010 at 7:21am
Same basic engine as the D17, although different higher compression pistons, the 175 has a different camshaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AKA.ON Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2010 at 7:57am
if you had a D17 block could you put the higher compression pistons without causing any damge? Thank you for the quick response.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2010 at 12:38pm
Yea, Ive done that.  Dont use cheap gas as detonation will break the ring lands.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2010 at 12:46pm
Not trying to be smart but the d17 226 engine is acceptable to about anything you can think of doing to one . the pocketbook or wallet is usually the limitation for that engine.
This page was generated in 0.422 seconds.
