HD16 Clutches
alogan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alogan Quote  Post ReplyReply Direct Link To This Post Topic: HD16 Clutches
    Posted: 16 Apr 2014 at 9:18am
We have a 1965 A/C HD16 dozer that we have spent over $10,000 on the engine and clutches.  Last Wednesday the steering clutches would release a little bit if you pulled hard enough and long enough.  Thursday they worked fine, very normal!  Friday the clutches would not release at all.  Cracked a line and nio fluid being pumped.  Looking for solutions and or suggestions.
James Coons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Coons Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2014 at 9:30am
To start how's the fluid level? Also check to see if the filters or pickup screens in the steering clutch system are clogged. It may help if we know the version of HD16 your working on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2014 at 3:02pm
Suction screen or leak in hoses or pickup tube for pump .
This page was generated in 0.183 seconds.
