7060 alt.conversion
david l wilson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote david l wilson Quote  Post ReplyReply Direct Link To This Post Topic: 7060 alt.conversion
    Posted: 01 Mar 2010 at 11:06am
my 7060 has a neihof alt and it quit charging .i bought a delco replacement from agco but it uses 4 wires does anyone know how to wire it up so tach.will work.thanks david l wilson
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2010 at 1:56pm
David are you including the big battery wire in that count because most of the delcos I've seen have a three plug terminal and a stud for the battery wire ? Niel
jmm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmm Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2010 at 5:49pm
the last couple I have replaced, I took the alt. apart and attached a wire before the rectifier.  Mine had 3 wires going to rectifier (input) and I attached to one.  works good
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 1:05am
go to your auto supply store and get one for an old chevy, 2 wire i think, take the one back to the dealer, lots of cash diff, make sure you tell them it's for a chevy and not a tractor or they will honk you on $$$ for the same alt
