is this the right hitch?
Seth Souerdike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Topic: is this the right hitch?
    Posted: 11 Apr 2014 at 11:20am
is this the correct sleeve hitch for a 712H? seems like its missing something? http://www.ebay.com/itm/ALLIS-CHALMERS-712-HITCH-/320760147085?pt=LH_DefaultDomain_0&hash=item4aaecb6c8d
There are no atheist in foxholes.
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2014 at 11:32am
NO! that's a drawbar hitch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2014 at 11:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2014 at 12:35pm
The older style sleeve hitch's used a chain from top lift rod to raise and lower them. Sleeve hitch is for plow-disc and some brinly implements. What are you wanting to hook up to it?
Edited by farmtoybuilder - 11 Apr 2014 at 12:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2014 at 4:38pm
the moldboard plows probably a brinly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2014 at 4:40pm
something like this .
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2014 at 7:03pm
on a 700 series you dont use a chain, it has a rod that hooks under the upper lift, i will try to get you a pic. this weekend.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2014 at 7:05pm
