clutch
Ronnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Topic: clutch
    Posted: 09 Apr 2014 at 11:28am
I have a 190 that i run in a 6000 to 8000 pound class the pump is guted and it runs realy good i am puting biger injectors in in a few weeks and i need a clutch the class has a 3000 rpm limit it is using the factory 2500 gas engin clutch right now it doesnt slup but the drive disk is going bad.
what would be a good clutch to run .
I would say it is making a bout 150 to 180 on hp it runs 5and 6 gear right now.
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 11:37am
When I pulled my xt bout 6 years ago I put a HD allis 200 clutch in it. I never knew the hp on it but it slipped the hydraulic pto at 175. And it would run 10,000 lb class with 20.8x38 in 6th gear. We just farm with it now and it's 126hp.
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 11:54am
That sounds like a good running 200 . I was thinking bout using a xt3 clutch   u think it is the same as a 200
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 11:58am
Wood a clutch out of a 105 white work i can put heavy springs in one for a 105
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 12:46pm
Xt series 3 + 200 are the same, pretty much, but some have 6 pads and others have 4 pad ceramic,   get a 4 button ceramic clutch disc, the pressure plate also needs heavy duty springs, i think the shops call them Lavender color, Unique Automotive in Jonesburg Mo can put one together for what your wanting to do very resonable priced too,
Bob C IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 4:42pm
WTF!!!! 190 hp 5th or 6th gear.... put in a SFI setup before you kill someone.... kill yourself that's one thing but someone else!!!!
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 5:33pm
Bob he is running a 190XT  tractor at a 150 hp
Edited by patrickmull - 09 Apr 2014 at 5:34pm
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 6:23pm
If you are running over rated engine rpm I would highly recommend a steel flywheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 7:57pm
Over rpm over hp... Ok give em somethin to talk about over on pulloff... It ain't my ass, I'm just givin advice.. GO FOR IT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 9:08pm
Sorry at in pa I ment 190 not 200
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 9:14pm
I am using a xt3 flywheel can I get a steel one as a hole set up I would like to get something to handle 400hp and 7 gear or am I going to be fin running the xt3 fly wheel and a heavy pressure plate with a 4 button disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 9:20pm
400 hp wow.... Not only the flywheel but how bout the cast iron 2 speed between your legs? Hope your finished with your jewels....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2014 at 6:03am
The pd is down the road for now i wont to keep it i was going to have a pd bilt out of steel i realy like having shift on the go and im not going strate to 400hp i no i can our run a 180 hp tractor so im just gessing im a round 150 to 180 i have plans to dyno it in a few months to get an exat number i am just wonting to do this clutch job once
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2014 at 11:12am
So i need a 4 pad drive disk and a heavy 190 xt3 or 200 pressor plate
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2014 at 11:21am
I just reread ur post, is this a gas tractor?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2014 at 12:31pm
with a gutted pump and big injectors???????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2014 at 1:12pm
No its a diesal 301 out of a 8010 with a guted injection pump and maby 3000 rpm g springs
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2014 at 1:14pm
If u read the post it has gas engin pressor plate and drive disk not a gas engin
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2014 at 3:12pm
Ok, gottcha,,
