D 19 diesel
WildBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WildBill Quote  Post ReplyReply Direct Link To This Post Topic: D 19 diesel
    Posted: 09 Apr 2014 at 12:17am
Well here it goes.I know this Is a soar subject with the Buda. Hoping Ed or Dr. Have some insight on what can be done to make this a Puller. Suppose give up early. Any old knowledge is good. What weight class ?
Allis fan for life !   B,C,2-WC'S,WD45G,D19G,190xt ,LLSS 8010, terra tiger refurbished
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 6:20am
Save your $$$$.....poor choice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 6:41am
Get a 180 , but i kno how it goes sometimes your just stuck on a certain model, the Buda diesel in those just cant take high horses
Edited by DougG - 09 Apr 2014 at 7:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote WildBill Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 7:03am
For sale 1962 d19 Diesel . Not beat up straight tins . Runs really nice never had a loader on it. Draw bar shows low abuse. I'll post it to classified section with photo. Like I posted ( soar subject) but gotta ask.
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 7:50am
put a 301 in it
Post Options Post Options   Thanks (0) Thanks(0)   Quote WildBill Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 9:46am
I agree if someone has mounting plate pattern. I have 10 301 blocks and performance parts . I was only going to antique pull it and looking for little extra hp. Otherwise I knew it was a lost cause . Be sweet if a guy could ditch the energy cell head and install normal injectors . But then you run into the piston bowl being wrong so where does this can of worms stop!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 11:10am
a 185 plate will work along with flywheel and starter.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 12:35pm
If you're just looking to antique pull it with a little more hp, then do it. You can get a little more out of them with pump and injector tuning, but don't ever get your hopes up for over 100hp.  I can turn the fuel up to alot more than stock, however a Lanova cell engine will only produce more smoke and less power once you get to a certain point.
