6080 Puller
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: 6080 Puller
    Posted: 28 Feb 2010 at 1:25pm
Is there anybody on here that has any pictures of 6080 pullers. Has anyone seen or fabbed a narrow front. Tractor data says the lowest weight is 7590, would like to put it in the 6500 class. If any one has one they pull what class do you pull in. Also this tactor has no motor, what other Allis equipment had the 433. Would likley trade the FWA front axle, cab, and hyd arms for the parts that I need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 1:38pm
Sorry about the pic size.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 1:41pm
looks 2 me u got a project on yur hands ....
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 9:04pm
personally, i think if it were mine i would part the entire thing and put the money towards something a little more common. Custom parts are expensive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 9:09pm
I would go with a wide front if I could get the weight down to 6500. Dont know if I could shave 1200 lbs off of the tractor by going to 38" pressed wheels and removeing everything else I dont need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 9:14pm
F2 combines 78 and later used the 433 but don't have the crank thrust "fix" used for the tractors.
roosky01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roosky01 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 9:34pm
I think a 301 would fit in there very nice...
Government always finds a need for whatever money it gets.
Ronald Reagan
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 10:01pm
Is the 301 a bolt in as far as the torque tube goes. I was thinking of putting a V8 in it, but then I would only be able to pull in the exhibition class.
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 10:43pm
I bet you could sell the 4x4 conversion parts and use a D-17 narrow.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 10:27am
you can use the rear plate off a 433, it should bolt onto a 301. a 433 is a 4 cyl version of a 301. you'd have to redo frame rails.
