Allis B ?
51WD(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 51WD(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Allis B ?
    Posted: 28 Feb 2010 at 12:28pm
I have a friend that has a Allis B he would like to sell with attachments, I need to know where the serial # would be stamped on the tractor to identify the year and get some friendly advice on what it's value would be. I am including pics. Any advise is welcome.
Thank
Dean
51 WD serial# 95746 and 80949
58 D17 W/loader #10742
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 12:38pm
First off, what you have there is either a C, or a mix of a B and C.  Most deffinately a C rear half of the tractor, and from the pic of the serial number by the shift lever, it is a C.  The serial number starts with a C (I can't read the rest, do you know what it says?)  Also, the C's had a wider rear end than the B's, which you can tell from the space from the wheels to the fenders, as well as the different shaped drawbar.
Don't feel bad, I bought a C this past fall that was advertised as a B as well.
What kind of front end does it have?  If its a narrow, its a C front.   If its a Wishbone, its a B front (and you have a mix of a tractor).  If its a Square tube adjustable front, it could be either a B or a C front until closely looked at.
**Edit** Ok, looking at the pics some more, I see the rear of the wishbone of the front end, so it must be a wide front of some type.
But the fenders are throwing me off. C fenders should have two vertical ribs in them, not smooth like these, which suggest they are from a B?
I also see all the parts (I believe) for a one bottom attached plow. (although the mounting bracket is slighty different than the one on my C.)
And you also have a hodge podge of a field cultivator too.
As for price, more info would be good (and a pic of the front of tractor).  Looks like new rear tires?  Are the rims all good?  Does the tractor run?  Good?  Stay in all gears?  Looks fairly complete, has a mag, and some kind of lights (original ones?)  At this point, I'd say start in the 800-1000$ ballpark, and go up and down depending on more info.  It's so hard to put a price on these kind of situations though until you know more info.  And keep in mind, B's and C's are everywhere!  A lot depends on what you want it for, and what you're going to do with it too....
Hope this helps!
Edited by Jacob (WI,ND) - 28 Feb 2010 at 12:57pm
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 12:48pm
Looks like the serial# might be C8793 which would make it a 1941. If it's 4 digits it's a 1941 either way.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 1:55pm
Unless the photo has been reversed that's a left hand plow.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 3:04pm
Dusty
Good eye Dusty!  I didn't notice that, and looking yet again, I see the matching Right hand plow under the rear field cultivator I believe.  If everything is there to attach and use both plows on the tractor, that adds value to the unit in my opinion.  Do you know if there are two hydrolic cylinders on the tractor, and a valve to select which cylinder you want to use?  again, if that's all there, its a plus!
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 3:15pm
Originally posted by 51WD(WI) 51WD(WI) wrote:
Yep, see, there are two mounting brackets for where the front of the plows mount to this front mounting bracket.  Must be a two way plow set up, cool!
Anyone know anything about the way the plow mounts on the top ( to the rock shaft)??  What is the deal with the "half circle" mounting brackets?  The ones I have, and have seen just mount with a half circle on the END of the bracket and a bolt mounts that arm to the rockshaft arm (if any of that makes sence?)??
**Edit**  Oh never mind, after thinking about it, I answered my own question, that is because it is a two way plow, it has to be able to pivit on the rockshaft for the second plow.
Edited by Jacob (WI,ND) - 28 Feb 2010 at 3:35pm
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 3:18pm
Jacob, I missed the right one. I have 2 pair of right & left plows for my G. It has 1  hydraulic cylinder to lift them and a latch for each. You pull a release lever for which ever one you to drop.
The B & C may be the same way.
Dusty
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 3:18pm
Interesting situation.  Yes, the rear looks like that of a C. The rear lift arrangement is that of a C.  The tractor does have the selector valve and two rams. Looks like a C plow front drawbar. The Left Hand plow also includes the arrangement to attach to the rear lift bar.  However, the mag picture shows the bracing (wishbone) for a B front end.
Quite frankly it appears what is shown is in good order.  Does it turn over?
Yes, Perhaps more pictures are in order.  Especially wide view of tractor.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 3:40pm
What I can see in the pic with the serial # it looks like it starts out "C" to me. Do the steering arms and drag link point up with a gear box in the front pedestal, or is the drag link directly connected to the ft axle? Arms up = C. Direct to ft axle = B. Then again, there's always the chance of mixing and matching B and C parts to make 1 tractor.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 4:28pm
I'd bet it has a C wide front because the B would have a pivot plate on the front rather than a casting as in the magneto picture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 51WD(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 4:45pm
Thanks for all the info! The friend of mine that has this tractor has been in posession of it for the last 12 years.It belonged to his grandfather before he died. Suppositly his grandpa bought it from a friend who worked at the Allis Chalmers factory.  I was at his place this weekend and saw it for the first time. The pic I took of the stamped # must be the correct location? if so, that is a "C" in front of the 4 digit number. Sorry I don't have a pic of the front, I thought I got that one. The front axle is a straight tube and adjustable. It does run well and the tires are excellent, probably 12 to 15 years old. I will try to get more pics this week.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 7:09pm
I agree with Dick L. It is a C with a factory wide front. I like the wide front C because most Cs were narrow fronts. Probably  the C fenders rusted out like they like to do and were replaced with CA fenders.  Original style C fenders are not reproduced.
   I like the tattered canvas covered seat. It looks like it came with that C when new. I would like to send 51WD a swatch of new seat cover material and see if what have looks to be a close match to whats left of that old original.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 7:57pm
I noticed the seat too Ken, and was wondering the same thing.  I see this one has black piping around the seam.  Are the other old originals like this too?  I am curious.
And the fenders, they are CA because of the bullet light right?   I just assumed B fenders, but B's didn't come with bullet lights, so I guess that can't be.  See you learn more every day!
Jacob Swanson
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 9:48pm
Yep, looks like a pretty nice one. Why are they always somewhere far-far away from me? I would love to have a wide front C. I would also love to get hold of  a two-way pick-up plow and the accessories for those. Looks like everything is there. May be a set of 80 series cultivators around to go with that rear field cultivator.
Looks like tractor has been taken pretty good care of.
Noticed the mag looks different than my 1946 does. I can see it says Allis-Chalmers on it. Kill switch tang is in a different spot too. Maybe a later model mag?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 10:03pm
I think I should have said, the seat Could Be original. A closer look at the stuffing in the pictures, looks like a chunk of old foam rubber. It has been many years since I sat on a original and I can't say for sure it had black piping back then. When our B seat got worn out and had holes in the canvas no foam rubber was under it. I remember some other kind of padding between the coil springs and the canvas. Layers of different stuff.
    If anyone needs the pieces under the foot rest on the right side (part of the plow debth control linkage) I have a extra. I also have a extra pair of C plow drawbar mounting brackets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 51WD(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2010 at 6:54am
Here are 2 more pics of the front and left side, she really is in good original shape and has been indoors.
Dean
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2010 at 12:40pm
That sure looks like a CA front axle, steering gear box and drag link. Maybe a CA engine bolted up to a C torque tube, tranny and rear?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2010 at 12:54pm
The CA wide and narrow fronts have two cultivator bosses that stick out the bottom front. That is a C wide front.
That also has the short arms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 51WD(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2010 at 3:10pm
can someone with a 41 C post a pic  to compare?
Dean
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2010 at 4:17pm
I tried to post a pic of my 41 C but it won't let me. Says this page cannot be displayed when I go to add a photo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2010 at 4:48pm
I have not been able to get on the farm equipment forum all day. Bright House's Road Runner puts up a dialog box that says, sorry, we couldn't fine ww2.allischalmers.com. That's not the address that I have book marked.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2010 at 5:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2010 at 5:49pm
That air cleaner is off a CA of 52-53 vintage or newer. All the early CA's and C's had the 2 clips holding the pan on. Looks like everything else is C. 51WD, if you could look at the engine number stamped on the right side engine rear flange, it might give some insight into what engine is in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 51WD(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2010 at 6:03pm
When I login, I am having the same problem as Dusty!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2010 at 6:36pm
I tried to edit my post to say the left side engine flange and I can't get in to edit it.
David Gantt N.C. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gantt N.C. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2010 at 8:02pm
I got to go with Dick L on this one (C wide front) but the breather looks like CA, would be a nice one to have, thanks for showing.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2010 at 8:13pm
It has the short steering arms that were only used on the very early Cs. Kip
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2010 at 9:15pm
Also just noticed it has the big hole in the hood for the muffler. Wasn't that for a CA? Just my opinion, I think the gentleman that owned this old wide front C took very good care of it. When some parts started rusting out, he found a CA for some donor parts(hood, fenders, air cleaner). If you look at some of the first pics, you can see the strip that covers the wiring to the rear lights and bullet lights is pretty rusty compared to the hood and fenders. The fellow may have used the tractor to spread fertilizer with at some point. I know that's what rusted the fenders and sheet metal off my grandad's C. (that and 50 years sitting out in the back yard with only a bucket over the exhaust.LOL!)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2010 at 9:18pm
Yep, nice looking unit you're looking at there, definitely a C, with a few CA parts mixed in.  I'd say go for it.  If I was in the market for another C (which I'm not, though I'd think about trading one of mine for a wide front one.) Anyway, I'd easily go to the 1200$ range with this one, if is as nice and runs as nice, etc.... as it looks.  keep us posted!
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2010 at 9:21pm
Ken, if that's foam rubber under that tattered canvas, it's not the original seat. The one on my grandad's C had been covered, but they used a canvas duck material similar to what was supposed to be on it. The seat has springs inside, a lot like an old mattress box spring. There was horsehair padding between the spring box and the covering. Grandad took an old quilt and added some extra padding under the canvas when he covered it.
This page was generated in 0.246 seconds.
