WD puller
kniesshy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kniesshy Quote  Post ReplyReply Direct Link To This Post Topic: WD puller
    Posted: 05 Apr 2014 at 12:44pm
What size fuel line should I have for a 350 CI engine? Also can you get any horsepower out of your stock intake/exhaust manifold? Nothing done to it but there is a port polish job on the head. Another question is will a fuel pump help any?
pohlman249 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pohlman249 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2014 at 11:51pm
At least port match the manifold. If you can whack off the carb mount and run a larger pipe with a flange and larger carb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2014 at 6:05am
A 3/8" rubber fuel line is big enough. It has to be in a straight line and no droops in it. The needle&seat may need to be drilled out to allow more gravity fuel flow if you're not using an electric pump. This is the only advantage to electric pump as it will see to it the carb bowl never runs dry or low on fuel. More to maintain and go wrong and some clubs will not allow it. I use 3/8" rubber line with a drilled out needle/seat with 400 cubes and 2400 RPM.
