WD45 with WC tranny |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Topic: WD45 with WC trannyPosted: 02 Apr 2014 at 7:43pm |
Read a cool article the other day about a guy that removed the Hand clutch housing and put a WC tranny in it's place. Made a coupler shaft to the original transmission and now has 16 gear choices (4x4).
It was being debated if legal since it is using stock AC components I guess Thompson did something similar with their HiCrops? |
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
patrickmull
Posted: 02 Apr 2014 at 8:22pm |
I wondered about that also being legal or not he pulls in oregon so i don't know how there rules read
WildBill
Joined: 26 Aug 2012 Location: Mandan,ND Points: 190 |
Posted: 03 Apr 2014 at 10:22am |
Too many choices . Only need 3 gears . R,1,2. but you need right ratio for hp and tire set up, I thought of that set up but rather save weight and reduce rotating mass which robs power. Keep it simple
Allis fan for life ! B,C,2-WC'S,WD45G,D19G,190xt ,LLSS 8010, terra tiger refurbished
mattb
Posted: 03 Apr 2014 at 1:58pm |
I have done two like that works good and the wc trans is lighter than the handclutch housing. Usap told me they didn't have a prob with the two trans setup and have been pulling them with mahnke for several years.
Juiceman
Joined: 26 Aug 2013 Location: West Virginia Points: 110 |
Posted: 03 Apr 2014 at 3:02pm |
Well thats interesting i was wondering how usap thought of them. I interpreted the rules a little different than Mr. Peterson in his discussion on this subject regarding the usap rules. Have any of these types of tractors been able to pull at Tunica? I've never checked in about their rules
mattb
Posted: 04 Apr 2014 at 8:22am |
Never been to tunica if your worried about it put a cover over the frame rails and tell everybody you put a diesel ring and pinion in it usap told me its no different then a Sherman under drive or an m and w in a farmall.
WildBill
Posted: 04 Apr 2014 at 9:47pm |
While your adding extra transmissions and gears for the 12,000 antique superfarm class might as well hook the corn chopper up bring it along for the show. Look simply put extra rotating drive line assembly's steal usable horsepower that needs to be put to the ground. I would approve banter or profab underdrive cause there efficiency is incredible. Regardless all three clubs I pull with this wud not fly with tech.
blue924.9
Joined: 22 Mar 2013 Location: George Iowa Points: 1089 |
Posted: 06 Apr 2014 at 10:20am |
i see your point, but if you add another transmission in there i agree it will take up power not arguing there, but the couple horsepower it would take, it would multiply the rest of the horsepower by x amount of times would it not? there fore you would lose power from the engine but multiply the power put to the ground by an amount that would overcome the power lost
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
WildBill
Posted: 06 Apr 2014 at 12:11pm |
Negative ghost rider . Your dealing with such a close ratio for 4 Mph or 3.5 or 5 doesn't really matter it's a waste of time. Especially 4500 lbs class or 5500 lb class. If you have a 226 engine built right you don't need another transmission !! Horsepower to weight ratio. Do the math. Unless your pulling a house out if the ditch somewhere ya probably need double down . Hell might as well put a 2 speed splitter In the rear end while your at it ?? More options while your hooking up to the sled LoL. Advice = Keep it simple.
blue924.9
Posted: 06 Apr 2014 at 8:36pm |
WildBill
Posted: 06 Apr 2014 at 8:44pm |
In the long run I hope you do super all season pulling .
Josh Day
Posted: 06 Apr 2014 at 8:49pm |
I'm going to be stupid here but, shouldn't it only have 8 gears or is it high low? And how does putting two trans work, because if the WC trans is slower then the Wd in 4th gear, wouldn't it drag slower, or do you not put them both in gear at same time. Sorry for the dumb question
AC's 75' 7040, 64' D-17S4, 55'WD-45, 54' WD-45, 53' WD-45, 53' WD, 52' CA, 36' WC. IH 656. Deere's 38' A, and 47' A
DrAllis
Posted: 06 Apr 2014 at 9:51pm |
With the front WC tranny installed in the normal position, with it in 4th gear, you'll have four normal WD speeds from the chassis tranny. When the front WC trans is in 1 - 2 or 3, you'll have three speeds slower than normal. I'd count 16 selections, but maybe some duplications. Then if you do two reverses, that would be another forward gear too. The intent was to have creeper gear speeds, which it does.
Josh Day
Posted: 07 Apr 2014 at 5:19am |
So how fast would it go in 4/4 gears? Because that would be fun to have just to play with lol
2wise4agm
Joined: 19 Aug 2011 Location: Smithton, MO Points: 538 |
Posted: 07 Apr 2014 at 6:11am |
The same speed as just having one Trans and being in forth gear.
blue924.9
Posted: 07 Apr 2014 at 7:50am |
https://mail.google.com/mail/u/0/?ui=2&ik=6a230f348c&view=att&th=1452ec8d1598b4bb&attid=0.1&disp=inline&safe=1&zw
here is a link it has speed charts
blue924.9
Posted: 07 Apr 2014 at 7:51am |
thanks bill Edited by blue924.9 - 07 Apr 2014 at 7:51am |
mattb
Posted: 07 Apr 2014 at 11:05am |
How much horsepower does a 20lb spinning handclutch take. A lot easier to pull 3mph at 2100 rpm than 1400 with 38s. I wouldn't see a advantage with 28inch rubber just 38s
Dirty Harry
Posted: 09 Apr 2014 at 2:13pm |
Oh by the way I am from Washington. Yes I did add a WC transmission in front of the WD45 transaxel. None of my gears repeat. It gives me 6 gears from 4.2 mph to 8.1mph at 2300 rpm with 18.4 38s on 20s. It's no different than cutting a custom gear or adding a aftermarket underdrive. I didn't change the wheelbase and no custom connector shaft is required. And I used factory parts. If you guys won't let me pass tech at some of your pulls that's fine I won't pull at your clubs. We pull USAP around here and they are cool with it. I am a younger guy (26) and I am excited about pulling. This is my third year. You older guys need to make sure you encourage the younger generation if this sport is going to last. If you wanna see pictures there is a Facebook forum Antique Tractor Pulling Forum. By the way a 12 to 1 compression 302 gleaner e-code is headed my way too. Thanks guys
