Allis Chalmers HD11E Clutch
jchance View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jchance Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers HD11E Clutch
    Posted: 24 Mar 2014 at 7:52am
hi all,
my clutch has gone on my HD11E, where can i source a new one i have looked everywhere.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2014 at 4:24pm
I have 2 HD11 wet cluch desassembly if I can help
Post Options Post Options   Thanks (0) Thanks(0)   Quote jchance Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2014 at 8:19pm
thank you, i think mine is a dry type clutch though
Post Options Post Options   Thanks (0) Thanks(0)   Quote jchance Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2014 at 8:21pm
how can i tell if a dry or a wet clutch ?
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2014 at 10:24pm
HD11E serial number 8321 should be a wet clutch- reservoir under rear of oil pan, spin-on filter on rear of clutch housing.   Wet clutch came around 6400 serial number range, 1961 or so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jchance Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2014 at 10:47pm
yes it has the spin on filter on the clutch housing in the rear underneath.
so it must be the wet clutch.
would i just need to put new friction plates on or do i need a whole new clutch
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2014 at 4:29am
Before you removed the cluch make sure your oil tank is full and check if your cluch  pump and oil filter are in good condition.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jchance Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2014 at 6:54am
thank you
how do i check if the clutch pump is working correctly ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2014 at 4:24pm
Make sure your oil tank under rear pan is full and with the motor running you could disconnet a hose from oil filter you should see if the pump have a good pression or disconnect the hose from the small pump near the fuel pump
