D19 Finals on a 190XT
Mark D. View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark D. Quote  Post ReplyReply Direct Link To This Post Topic: D19 Finals on a 190XT
    Posted: 26 Feb 2010 at 11:36am
I have heard that D19 finals can be used in a 190XT rear to achieve a faster final ratio in a puller.  What all is needed to get them to fit??  Just brake shaft and bull gears?  Can the brakes work from the XT?  thanks
Mark
Miss Behavin - D21 Super Farm
Xcessive Tinkering - 190 XT Hot Farm Puller
Watch on YouTube - http://www.youtube.com/watch?v=J2TX1Af7aoA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 12:39pm
D19 bull gears and bull pinion gears.....the hard part is finding a new enough D19 to have the "fine" splines on the bull pinions so they will fit into the 190XT differential side gears. Old D19's were coarse spline like WD's and old D17's.
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 3:09pm
Mark if you find out you need the bull pinions let me know we have 3 D19s in the parts yard and I can pull some out and see if they are what you need Niel
Gary IN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary IN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 4:22pm
Also have a parts d 19 go to battle creek quite often if thats close. Thanks Gary IN
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark D. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 7:30am
Thanks!  Does anyone know the serial number break on the D19 to get the right one?  Also, if I have a 190XT series III  with the big axles, will those fit the D19 bull gears?  Thanks Again!
