tire care
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: tire care
    Posted: 20 Mar 2014 at 6:28am
I just got a set of tires to stick on  my puller project.  They are just starting to have some checking in the center of the tire between the lugs.  I want them to last a looooooong time as i spent a pretty penny to get the size, tread wear and rims i wanted.  Is there anything i can do to prevent any further checking/cracking?  They are old and hard,  maby drying out?
16.9x34  COOP 30 degree? tread
Edited by CAL(KS) - 20 Mar 2014 at 6:29am
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2014 at 1:14pm
I don't know a whole lot about keeping them from cracking, but what I do know is one if the best things you can do is keep them inside on concrete.
1950 B, 1952 pulling wd, and 1954 wd45
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2014 at 5:16pm
Keep them out of the sun!
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2014 at 9:59pm
Use them regularly. When the tire flexes the rubber stays softer. Tires that sit in one spot for long times will fail. Inside storage will increase the tire lifespan greatly.
