Dead weights
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Dead weights
    Posted: 14 Mar 2014 at 9:09pm
I guess I don't understand them
[TUBE]http://youtu.be/li_HZhOWuk4[/TUBE]
Charlie
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2014 at 9:26pm
that don't look safe
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2014 at 10:45pm
Its easy to read the track.   lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2014 at 6:07am
I am not sure but does that front tire ever turn
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2014 at 7:36am
Thats good for it   Thumbs Down
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Allis-chalmers wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2014 at 7:37am
Damn that's a good way to destroy a drive train!
big dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote big dale Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2014 at 7:42am
That's taking "drive it like you stole it" to a whole new level!!!
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2014 at 10:36am
I think, if you talk to most of us oldtimers, this is how tractor pulling started in our areas.
My first time was in 1972 in the 9900 lb class on a dead weight (stone) boat on my Dad's 180. 20' was a full pull and you got 2 hooks to go the 20'. There were over a dozen tractor's in my class and I got 2nd. I was immediately hooked (no pun intended!).I don't remember anyone getting that much of a chance to get the boat moving, but we were talking about field stock farm tractors at that point.
In 1973, we started pulling on the weight transfer sled.
It was definitely the roots of tractor pulling and usually started over a neighbor rivalry of "my tractor can pull more than your tractor...)
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2014 at 10:21am
The annual tractor show at Sunnycrest Orchards in Sharon Springs NY started out with the old stone boat dead weight pull. It was that way a few years before it got big enough to get a transfer sled. We used to go full track length(if you could) pulling both directions. Don't recall anyone ever using this technique though.
pohlman249 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pohlman249 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2014 at 10:25am
Around hear we started with step on sleads and believe that lasted into the late 80`s. It ended. With a puller getting his ankle roled under the pan... dead weights make absolutely no sense to me..
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2014 at 11:52am
Hey, who wants to loan that Guy a tractor! The scrapyard is in his future!
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2014 at 1:05pm
 It discrimenates skinny people.
Dugalech Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dugalech Farms Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2014 at 1:56pm
I am the owner of that D17. We are from Michigan that is a high popular sport here. There are pull all over hear. Yes it is hard on the tractor. The only thing I have broke is Right and left hand final drives only because I had 24.5-32 on it and tried bouncing it. There are two ways to get the boat moving one is to bounce the other is to do a high flying wheely then bring it back down so u will brake the boat loose. We pull up words of 700%. If you guy are intested in seeing more of this pulling go to MMOGTA.org or on facebook at Michigan cement pullers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dugalech Farms Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2014 at 2:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2014 at 3:16pm
Thanks for coming on DF!
Charlie
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2014 at 3:31pm
They still do some around here on dirt. And even some dead wt. pulls for garden tractors. It gets interesting when weight gets high! The begining of tractor pulls.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2014 at 4:49pm
Only thing I think that's interesting about that pull is the D17 with the 200 4 cyl. from a 6000 series! lol
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2014 at 3:54pm
As mentioned above, it's very popular here in Michigan. Technique  and being able to read the track and tractor balance is very critical, it sorts out the talent and wannabes in a hurry and the video of the above is not the way to do it. It's not hard on the tractor, when I was pulling dead weight a lot, we would do at least two pulls every week for most of the season and more during fair time, pulling two or three weight classes at each pull, and I never broke anything, and one clutch lasted seven years. The big deal here is that you have to get it moving before you can pull it, there is no gradual increase in weight like a transfer sled has. Once you think you have it all dialed in, then make the switch to steel and start all over again, it's a real art to be smooth on Tip-Toe steel when the percentage starts to approach 250 or 300 %.
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2014 at 12:31am
I'd think an old case-o-matic slip'n slip s'more would rule this type of event.....or maybe it'd never move.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dugalech Farms Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2014 at 9:46am
Ken from MI You are wrong that is how you make the boat move on cement. How dirt is a different thing. Cement take a lot of horsepower rough rides and maybe alittle screw loose behide the wheel. I have pull all different kinds of pulling. And cement is by fare the most fun pulling you will ever do.
Theres alittle steel wheels for you.
RWR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RWR Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2014 at 8:43pm
I think I saw Mike nein on you tube doing some dead weight pulling and it looked like he was doing some good pulling
graveyard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote graveyard Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2014 at 11:59am
In our part of ky that is 90 % of our pulls. We do it on dirt my D17 hangs in their pretty well with the old deeres and farmalls
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2014 at 12:05pm
And that picture is why our club requires wheelie bars on EVERY tractor no bars no hook .... if I was flaging you would have already been shut down
RWR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RWR Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2014 at 8:58pm
what is the best tires to use
