301 from gleaner M into 190
screwylouie010 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwylouie010 Quote  Post ReplyReply Direct Link To This Post Topic: 301 from gleaner M into 190
    Posted: 10 Mar 2014 at 9:41am
so i found a 301 on ebay from a gleaner M. it comes with the turbo, radiator, engine mount and the air cleaner. it has the inline injection pump on it. says it runs good with little blow by, but has a miss at hiring rpm. my experience with those minnimec pumps is that it either is getting air or possibly the governor is messed up. but im wondering what you guys think of putting this in my 190 which currently has the gas engine, it runs great but would rather have the diesel. far as i can tell i will have to open up the front plate for the hydraulic pump. also i have to replace 3rd gear as it pops out and rebuild the power director, looking for any guidance of what parts i will need or where to get them. i know already to  get the pd plates for the 200/7000 tractors. thanks guys
BPM75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BPM75 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 12:47pm
I don't know about the M but the one I have out of a G does not have any way to mount the pump on the frt plate, you may have to find a plate for a tractor.
59 D17 gas nf, 66 XT 190, 69 220.
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 12:56pm
Seems like the oil pan will have interference problems with the front axle also. ( If I remember correctly )
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwylouie010 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 1:18pm
here are the pictures he sent me of the fron cover where my hyd pump is. the plate with 2 bolts on the front side looks identical to my 190. the back side looks bare , but with 4 bolts in about the same location as the mounting bolts of my pump. i am not to worried about the oil pan clearance. i can modify this 1 or fabricate my own, or if it is easy enough and cheap i would get the correct one. thanks for the input guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwylouie010 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 1:20pm
ok, i kinda got it now
Edited by screwylouie010 - 10 Mar 2014 at 1:26pm
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 3:21pm
Looked at the engine on Ebay and I guess I never have seen an M gleaner engine befre... this one has the water /oil cooler line on the intake side of engine with the volute from water pump also on intake side. I have always seen them on the exhaust side.... that normal for the minnimec pump engines? Will there be room under the tube for the hyd. pump?
DON G View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DON G Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 3:44pm
WE PUT M ENGINE INTO 7000.
yOU WILL NEED SOME GOOD PULLERS TO CHANGE FRONT PARTS.
pohlman249 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pohlman249 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 3:55pm
Eather pull the cam gear or the cam and swap the covers.... I'd 're torque the head too.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 5:24pm
Minnimec pumps use the same front plate as the later roosamaster like whats on the 7000 series. Get a front plate from a "7000" and put in on the front and she will bolt right in.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwylouie010 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 7:08pm
yea looks like there should be room for the pump. so i just need the front plate from a 7000 and the pump should bolt right on. thanks for all the info guys. here is a video of the engine running. it does need an exhaust manifold gasket.
 on edit, guess i cant get the video to load
Edited by screwylouie010 - 10 Mar 2014 at 7:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwylouie010 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 7:12pm
here it is
[TUBE]6t3RRFpJVNs&feature=youtu.be[/TUBE]
Edited by screwylouie010 - 10 Mar 2014 at 7:16pm
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 7:20pm
There were several versions of the M diesel engine. Early ones used a DB style roosamaster I think. They were very much like a 200 engine. I don't remember any of the M's using the SIMMs (Minnemac) style pump. I do know that the L's did use it for awhile. The later M's used a DM style pump like a 7000 if I remember correctly. If the 190 uses an engine oil pump driven tachometer drive, you're going to have to stick with a cam and cam driven oil pump system. Otherwise you could go with an alternator driven tachometer, but I think that uses a different tachometer head. There's a lot more to these projects than what you might think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwylouie010 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 7:42pm
right now the tach is driven off the distributor, or is atleast supposed to be. now on the minnmec, if it is like the 1 on our ford tw 5, the tach is driven off of the end of the pump. i did ask the seller if and where the cable hooks to
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 8:34pm
No tach cable on the combines. They used a magnetic impulse pickup on the rear PTO pulley.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 8:49pm
I did this. It is a lot of work but doable.  1 front pulley will have to be 190xt - combine will hit front cast iron. 2 pan will hit axle - have to  lower the axle. 3. oil cooler will hit rear firewall - it will have to go. 3 Frame will have to be cut on RH side for fuel pump and left hand side for oil filters. 4 Radiator will have to be raised 2.5" approx. Lots of flex hoses as radiator outlets not the same. (I spaced up the front side sheets leaving a gap between the bottom and the cast iron front )  5 id did not change front cover  drilled with holesaw opening for pump drive and used existing bolts and then fabricated clamp for rest of attaching drive parts.  6 clutch linkage will have to be modified.  7 front plates have to have mounting flanges welded to them for front attachment points. 8 starter drive change. 9 tach fits right into back of simms minn inline pump. 10 have to fab bracket for throttle and fuel shut off cables.  (someone had maxed out the fuel screw on the simms pump. I dyno'd and clutch slipped at approx. 165 hp)
just use it fro cruzin and pulling a grain buggy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwylouie010 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 8:51pm
ah i see, thank you. well ill figure something out, still waiting to hear from the seller if there is a provision for one on the engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwylouie010 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 8:54pm
thank you tbran. that is a lot of useful info. but what do you mean you fabricated clamp for attaching rest of the drive parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwylouie010 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 9:04pm
also will my flywheel and clutch bolt to the 301? i dont know what the engine will come with in that department. but i believe it will come with the starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwylouie010 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2014 at 7:58am
also, tbran, do you have any pictures, that would be great
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwylouie010 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2014 at 9:55pm
well i bit the bullet and bought it tonight. cant wait for it to get here. now i just gotta get a hold of new power director plates and all the seals plus what ever i need to fix third gear. hope i can have it running to disc and plant with
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2014 at 6:09pm
the Simms pump was more common in the L, but we do have a few M's with the Simms pump as well one of which is a hydrostat bean special machine. I personally am not a fan of it. hard starting is the main downpoint.
the roosa is a much better unit IMO.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Jwmac7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwmac7060 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2014 at 6:43pm
My Gleaner M had a 426 in it not a 301
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwylouie010 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2014 at 8:33pm
it could have come from an L, was told it was pulled from and m. thought i remember when i was flipping through my Shoup catalog that the M had the 301 and M2 had the 426. as far as the hard starting, ill be advancing the timing anyways. i dont if the simms pumps on the Allis engines have it but on our fords we a have cold starting timing advance button on the pump. it makes a big difference when starting in the winter
Edited by screwylouie010 - 02 Apr 2014 at 8:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2014 at 9:33pm
This is not a simms pump engine but one that came from a combine... Not mine.  But one of the fellers on here Wink...  You can see his handy work, he had to raise the front on it, and a few other things. LOL It can be done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwylouie010 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2014 at 9:46pm
Think I saw the pictures from that build. Looks good. Engine should be here soon and have some parts on the way. Does anyone know what flywheel I will need? Ill put a fresh clutch in too. Would also like to find an intake stack like that one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2014 at 10:09pm
My suggestion, don't bother unless you really intend to use it in a real dust storm... I wanted one on mine then bought one with one and the dust bowl never got much in it during the year, but I made sure I kept the main filter clean....  That one stuck up in my vision and the bowl was at eyelevel too... And if the ground was rough, it shook too.  After I experianced the precleaner, I was not interested in looking at one on my other 190's....
DSeries4 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2014 at 10:10pm
I think Ms (1,2, and 3) used the 301 while the Ls had the 301 as standard engine with the 426 as an option.
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwylouie010 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2014 at 6:26am
thank you for your input JC. i will reconsider getting one now.i mean it looks cool and i dont think i will ever seriously farm with this tractor, its more of just a toy.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2014 at 7:26am
The start button on a ford simms is not to advance the timing. But it does allow the rack to go into start fuel, which also retards the timing.
