AC180 loosing hdy fluid in trans.
valleyranch5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote valleyranch5 Quote  Post ReplyReply Direct Link To This Post Topic: AC180 loosing hdy fluid in trans.
    Posted: 24 Feb 2010 at 9:26pm
  i reciently bought a AC 180 that is loosing hdy fluid in the transmission ,I'm quite sure it is the high /low range ,is this a common problem on the hdy operated hi/low ? I've had two 170s and never had a problems with the hi/low range on those ..  is it most likley the clutch pack or o-ring connections?   Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2010 at 9:56pm
Gary - the fluid is moving into the transmission thru the transmission input shaft (most likely) or the rear PTO shaft.  Based on postings over the years, I agree I do seem to see this more in 180/185/190 units than D17 or 170/175.  You're going to have to split it to fix it so I'd replace the the seal on the input shaft, bearing retainer gasket & PTO rear shaft seals (two seals there) plus the sealing ring on the PD while I was in there.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
