180 - 190 Needled Differential Pin
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Topic: 180 - 190 Needled Differential Pin
    Posted: 07 Mar 2014 at 9:56pm
e
Edited by O.P.S. Heads - 21 May 2015 at 10:37pm
Bob C IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 1:02pm
Would it be the same in my 7000?
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 8:24pm
Nope. Your 7000 has a four pinion differential. Instead of one straight pin and two spiders it is a cross with four spider gears. Won't work for you.
You can do the same thing to your cross but you would have to remove the differential and disassemble it to get the cross out. With the two pinion it is possible to change from a standard, non - needled pin to a needled pin without removing the differential. Remove the back plate / lift arm housing from the rear housing, remove the old and pin and install the new. Similar to doing a pregnancy check a Holstein.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 8:37pm
I almost think I'd rather have the holsteen
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2014 at 9:37pm
Bore the gears and press in a needle bearing.  MACK
WildBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WildBill Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2014 at 8:19pm
Any Left ?
Allis fan for life !   B,C,2-WC'S,WD45G,D19G,190xt ,LLSS 8010, terra tiger refurbished
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2014 at 11:28am
Yes. Send me an email or PM.
This page was generated in 0.130 seconds.
